Issues with PAC AOEM-HON20 Amp integration
Old Apr 24, 2012 | 10:33 AM
indohonda's Avatar
Default Issues with PAC AOEM-HON20 Amp integration
Hi,
I have a 2007 Accord Sedan EX-L no navi. I installed new component speakers in the front and new rear speakers. I also installed a new amp.
To connect the amp to the factory head unit I installed a PAC AOEM-HON20 amp interface.
I am having two isssues which I need some help with.
The first is that I am not getting any sound to the front speakers. All I hear is buzzing. I know that my ground is not good because I hear an altenator whine. I will correct this. But I am not sure why I am not getting sound.
The second issue is that my steering wheel controls do not work anymore.
I am not sure if my interface is bad or if I did something wrong.
As far as my install goes, I connected my new front speakers in the doors using existing wiring. Then I spliced new wiring in the cabin to connect to the crossovers. The rear speakers are brand new wiring connected to the amp. The amp power cable is on one side of the car and all the speaker wires and RCA cables are on the other.
Any help would be appreciated.
Old Apr 24, 2012 | 04:44 PM
Tyler Joyce's Avatar
Buzzing is sound. If they make some sort of sound then something is doing its job right obviously.
Fix that ground first and foremost. Ground wires are THE single most important thing in any electrical system.
Second, there is a wire that should go into your stereo harness that is specifically for "steering wheel controls". But first, are you talking about everything on your steering wheel, like cruise controls, horn, etc. Or are you talking about just the stereo controls on the steering wheel?
I would look at the diagram that came with the stereo and see if you hooked up the steering wheel control wire.
Fix that ground.
Old Apr 24, 2012 | 09:13 PM
glramos's Avatar
i have the same PAC adapter on my 2007 SE , and honestly i hate it , it makes a very annoying buzz static type noise , very different from a GROUND NOISE OR LOOP, your no sound problem maybe the gain on the adapter is probably turn all the way down , on my case the one side connector wasn't getting a solid contact causing other problems .
Old Apr 25, 2012 | 11:57 AM
indohonda's Avatar
I took everything apart last night and reconnected everything a dozen times to figure out what was wrong.
In the end, the PAC harness sucks. It does not clip into the OEM radio and therefore wasnt making contact on on side. So I pushed it and now everything works.
Not to sure if I like it though.
glramos
Apr 24, 2012 10:27 PM
PostRelease
Jun 1, 2010 12:01 PM
Prix03GT
Apr 7, 2010 10:06 PM
mlaccord
Apr 19, 2007 11:45 AM
syclone521
Apr 3, 2007 03:05 PM
