Kicker Sub
Old Dec 1, 2008 | 02:44 PM
  #111
finch13's Avatar
Default RE: Kicker Sub
I can pick up an Alpine Type-R 12 with the 2 ohm DVCs for $100... now what am I looking at as far as power goes if I keep the Alpine MRP-M350 amp if I wire connect the VCs with the jumper wires?
My amp spits out 350W @ 2ohms and 700W peak
Old Dec 1, 2008 | 02:46 PM
  #112
finch13's Avatar
My buddy has the MRP-M1000 and two 12 Rs right now... I'll see if I can use his amp quick...
  #113
t00fatt's Avatar
Ahh yes. Yeah that amp is no better than a Boss. It does not have, at all, the power advertised. So it will work with a 15" CVX but the bass is going to sound muddy and muffled. But if you plan on running that amp for a while, a ported box will help with the low power. But once you get a new amp I would throw it in a sealed.
Old Dec 1, 2008 | 02:49 PM
  #114
AccordLXMaster's Avatar
well what if i tune the amp will it sound slightly better for the 15"?? or should i just stick to the 12"?? until i get another amp?
EDIT: i also saw that for the 15" CVX there is a dual 4 ohm and a dual 2 ohm...why is it that dual 4 costs more??..i thought that 2 ohms was better than 4
Old Dec 1, 2008 | 02:56 PM
  #115
t00fatt's Avatar
I wouldn't give a single type-r 1000w, they are rated for 500w. Also finch what do you mean by jumpers? You wire the coils in parallel or series, no need for jumpers. A lot of people think this, and I think you're thinking this too. You don't need or would use a 2ch amp with a DVC. You just wire the coils either in parallel, where you would take the positive speaker wire, connect it to the + on coil1, and then connect a wire from the + on coil1 and connect it to the + on coil two. That is parallel positive to positive, ground to ground. Series is when you take the positive speaker wire hook it up the the + on coil1, then connect another wire to - on coil1, then connect this wire to the + on coil2(essentially a bridge between the two coils). Then the - on coil2 goes to the - speaker wire. If I confused you I can find a picture to better describe what Im talking about.
Old Dec 1, 2008 | 03:01 PM
  #116
t00fatt's Avatar
Tuning the amp will not produce more power, but prevent the amp from clipping (distortion) and hurting the voice coil. The reason the 4 ohm is more expensive is because it is the most sought after(usually they are the same price though). When working with a single DVC sub, there is only two options for the final load on each sub. A single 2 ohm DVC can only have a final load of 1 ohm or 4 ohms. A single 4ohm DVC can only be a final load of 2ohms or 8 ohms. And since most amp only support down to 2 ohms, 4 ohm DVC is more popular. But when you start working with more then one sub you have many more option for wiring them up. And I don't think your up for me to start explaining that one lol.
Old Dec 1, 2008 | 03:04 PM
  #117
noo i already understand that..lol..ive researched that many times...so i got that down...i gotcha...so if i jus got the cvx 12" would i be good?
Old Dec 1, 2008 | 03:05 PM
  #118
t00fatt's Avatar
I think you would be very good with a 12", I don't think you L5 has any more SPL than my sub of it even matches it.
Old Dec 1, 2008 | 03:07 PM
  #119
alrighty then thats what im goin for untill i upgrade everything...preciate it..ported or sealed?
  #120
