Light question
Old Oct 9, 2012 | 11:56 AM
MichelAC's Avatar
Default Light question
Hello Honda friends.
I don't know if it's a problem that I have or that it comes stock with the car.
I'll try to explain it
It's about the inner lights of the headlamp.
When I start the car with the handbrake on, there isn't a problem.
When I release the handbrake, the inner lights of the headlamps goes on.
Then when I pull the handbrake back on, it doesn't go off.
It only goes off when I turn off the car.
Other scenario.
When I start the car with the hardbrake released, it immediately comes on and also only goes off when I turn of the car.
When these lights are on, the high beam indicator on the dashboard is glowing a little, you can only see this at night.
Hope somebody can tell me if this is a ground problem, doesn't look like a stock feature of the car.
Old Oct 9, 2012 | 10:15 PM
Sounds normal for the Daytime Running Lights (DRL) that come with the Canadian Accords.
Old Oct 9, 2012 | 11:58 PM
MichelAC's Avatar
Thank you for the reply
Just checked it and when I'm turning on the normal lights, the inner lights go off and so is the high beam indicator.
Is it normal that the high beam indicator is glowing a little when these DRL are on?
Old Oct 10, 2012 | 12:04 AM
Very possible, as the DRLs are using the high beam bulbs; but, at reduced brightness.
Old Oct 10, 2012 | 12:20 AM
MichelAC's Avatar
Woow that is clear
Thanks mate!!
62maxx
Oct 26, 2006 01:04 PM
ukcoupe
Oct 18, 2006 09:31 AM
bigdude
Oct 1, 2006 07:03 AM
hotrod01
Nov 11, 2005 01:28 AM
