lights dimming
Old Nov 13, 2007 | 09:38 PM
srpowersuw's Avatar
Default lights dimming
For the past few weeks I have been noticing my lights dimming and brightening when I am driving at night. I took it to the shop and had the battery and alternator tested and everything checked out fine. Anyone else have this problem or have any ideas as to what might be causing it? Thanks for the help.
Old Nov 14, 2007 | 07:40 PM
pham9006's Avatar
Default RE: lights dimming
well do u have an amp and subs in the trunk? cuz if so, its drawing power which dims headlights. Happens to my car all the time. I put in a capacitor, which helped only a little bit, so u have to upgrade the alternator and battery.
Old Nov 14, 2007 | 10:08 PM
MacLeod's Avatar
AC compressor springs to mind. As does the electric fan that comes on periodically.
Both of these make my headlights dim whenever they kick on.
srpowersuw's Avatar
no amps, no subs, stock electronics
Old Nov 16, 2007 | 03:59 PM
jhowkins's Avatar
I have also noticed the same thing on my '03 EX-V6. It seems to happen when I accelerate, so I figured it had something to do with the alternator or wiring. I'm not sure, I wouldn't mind knowing why it happens as well.
**Note: This problem is most noticable while the high-beams are on.
(I too have not changed the stock electrical system)
Old Nov 29, 2007 | 12:18 AM
mayfew
Check this out. "The Big Three"
http://www.sounddomain.com/ubbthread...e/1#Post312025
Quote from article
"As many of you know, upgrading the "Big 3" wires in your engine compartment can lower the overall resistance of your entire electrical system. The effects of the lower resistance are typically:"
1) Reduced dimming and smaller voltage drops
2) More stable voltage and better current flow
3) Less strain on your vehicle's charging system
jon.hand
Jun 15, 2011 08:34 AM
steviebix
Sep 5, 2007 12:13 PM
HondagalGA
Nov 20, 2006 10:55 AM
Gebo
Oct 16, 2006 08:21 AM
DVan8504
Feb 2, 2006 10:18 AM
