Multiple Amps + JL Clean Sweep
Old Mar 16, 2008 | 06:15 PM
XeRoD
Default Multiple Amps + JL Clean Sweep
Hello All,
As a newly registered member and Accord owner I would like to make my first post meaningful. I did some searching and could not find anyone who talked about multiple amps with the clean sweep. I too want to keep the factory OEM radio and add an aftermarket system from my old vehicle. I have two amps I want to use:
5 channel Alpine (400 watts)
2 channel Kenwood (700 watts)
The issue I have is the Alpine accepts 4 RCA inputs (FL, FR, RL, RR) and I want to keep it that way for balance. In doing so I will need to put a Y adapter to split the rear speakers to get a signal for my subs. I have done this in the past but not with the Clean Sweep. Has anyone done this? If so did you notice any signal loss or interference with this setup?
Any thoughts , suggestions are appreciated.
BTW - I love my new accord = 31 MPG on the first tank - woohoo!!!!!!!
Old Mar 16, 2008 | 07:53 PM
RTexasF's Avatar
Super Member
Default RE: Multiple Amps + JL Clean Sweep
Welcome! Sorry I can't offer any information to help. I have the Clean Sweep but with a single amp and a Bazooka with it's own self contained amp. I just didn't want you to think this had gone unnoticed. I paid a pro to install it all and wasn't present when it was done. DO make sure to use the setup CD with the CSweep once complete. You will have a seperate volume control so figure out where it's going before you tear into things.
Old Mar 16, 2008 | 08:59 PM
XeRoD
All,
I decided to just go with a Scosche SLC-4 for now. It was only 17 bucks so I will see if that satisfies me. I will post picks of the install once complete.
Old Mar 16, 2008 | 09:03 PM
I see your also a New Member, so I wanted to Thank You for joining the HAF..
Old Mar 17, 2008 | 11:21 AM
RTexasF's Avatar
Super Member
ORIGINAL: XeRoD
All,
What is that?
Old Mar 17, 2008 | 08:17 PM
XeRoD
It's an inline converter (4 channel).
Old Mar 18, 2008 | 01:37 PM
RTexasF's Avatar
Super Member
Ah So, gotcha. Hope it works out well.
the cyclops
Jul 24, 2011 03:05 PM
mtrac
May 20, 2011 12:03 PM
UGA_alumni
Mar 27, 2011 08:20 AM
austinman3214
Apr 25, 2010 12:35 PM
badxdawgx818
Jun 8, 2007 06:48 PM
