Navigation system in 91 Accord
Old Sep 29, 2008 | 09:09 AM
el_espiritu
Default Navigation system in 91 Accord
Hi folks,
I want to build in a navigation system in my 91' Accord Sedan. It's a DIN Radio with included navigation from Becker.
Now I read that the system requires a speed signal from tachometer. Does someone knows if there's a wire available which provides this signal? Or do I need an additional transmitter/sensor?
Maybe someone has already a navigation system in his 4th generation accord?
Old Sep 29, 2008 | 09:12 AM
finch13's Avatar
Default RE: Navigation system in 91 Accord
There should be a blue wire running from the distributor to the tach for RPMs.
Old Sep 29, 2008 | 09:15 AM
el_espiritu
ORIGINAL: finch13
Hmm, but I don't need the RPM signal, I need a kind of speed signal. (And I have a manual transmission).
Old Sep 29, 2008 | 09:49 AM
finch13's Avatar
Oh you wrote tach... um what does the navi manual say? I know that wire is just so it can tell if you're driving or not and I know there's a way of bypassing it.
Old Sep 29, 2008 | 10:31 AM
el_espiritu
The manual says that the system requires a speed signal from the speedo cable.
But this is a manual spindle in these old Accord models. But maybe there is a cable anywhere else which provides this signal.
Old Sep 29, 2008 | 10:40 AM
falkore24's Avatar
As noted, it's likely just so that you can't operate the navi when you are driving ..... my Garmin just plugs into the lighter, so I doubt that the VSS is necessary for it to tell you where you are going.
Old Oct 9, 2008 | 10:08 AM
el_espiritu
Hmm OK, I understand what you meant.
But let's assume it's necessary, BECKER claimed that a navigation without speed signal is not possible.
The 91 Accord has a speed sensor in the transmission for speed based power steering. And additionally it has a electrical signal there.
Has anybody an idea what kind of signal this plug provides? And more important, which cable is the needed one?
I checked the service manual from Honda but couldn't find any troubleshooting on the speed sensor.
Old Oct 9, 2008 | 12:22 PM
t00fatt's Avatar
Have u Googled for a bypas unit for this model? When you hook this wire up, your going to lose certain functions while moving, it's a stupid safety feature. So your best option is to find a bypass code or a bypass unit, or you can work hard and hook this wire up only for it to mock you while you drive.
Old Oct 9, 2008 | 10:44 PM
19Accord97
Yeah, I got a bypass unit off eBay for my touchscreen so I can watch dvd's while the car is in motion. Funny thing is....I've only ever had a dvd in there once. The day I put the stereo in! lol
HaveaQ
Jan 14, 2011 09:59 AM
AkozySlo
Aug 21, 2010 11:09 PM
snowian
Jun 22, 2010 10:17 AM
alchemist007
Jan 16, 2010 05:14 PM
navistusa
Sep 5, 2008 05:06 PM
