need help on 97 accord radio
Old Dec 22, 2006 | 10:21 PM
thetangstr
Default need help on 97 accord radio
just got this new Insignia CD-player so i can throw my stock one into the river
it all worked out until i was trying to put the radio in the dash and the red wire(12v power) popped out
so I was like ****, so I reconnect and it WONT WORK
I check the fuses in the car and its good, also the fuses on the back of the cdplayer and they are fine. one thing I realized was there is a red indicated LED on the radio behind the face plate, and it blinks with my red wire unpluged, is that because of the memory wire?
can some1 tell me what to do, I will check the fuses under the hood tmrw cuz iz raining.
btw, what kinda car kit should I get for my accord and where can I get it? cuz earlier today I went to pepboys and they gave me the wrong one and they dont have the right one in stock.
Old Dec 23, 2006 | 12:15 AM
t00fatt's Avatar
Default RE: need help on 97 accord radio
The red wire popped out of what? The stock radio harness? Or the harness for the new radio? If it popped out of the stock radio harness, look at the other pins and see how they go in. Its prolly a metal piece, then the harness has a little plastic clip that comes down. Slide the metal piece back in the same way as the others, then push that plastic piece down hard. If you think its making good contact, check to see if your getting 12v from the wire. If your not then its a fuse somewhere.
Old Dec 23, 2006 | 03:56 AM
19Accord97
Get your installation kit from Best Buy. And i'm assuming you had a wiring harness adapter right?
djaycardona
Nov 26, 2013 04:07 PM
GMANCRX
Jul 15, 2013 02:50 PM
mamtsberg
Mar 17, 2010 09:15 PM
RecMK5
Feb 13, 2009 06:33 AM
reds2k1
Mar 20, 2006 11:49 PM
