94 Honda Accord Radio/Cassette...Does Not Turn On...Need Help!
Old Mar 20, 2006 | 12:02 AM
reds2k1
Default 94 Honda Accord Radio/Cassette...Does Not Turn On...Need Help!
Today, I plugged in the cigarette charger to charge my phone; however, it did not work so I pulled it out. As it was out, I've noticed that a broken plastic part from the charger was still inside the cigarette hole. This may be stupid, but I used a key to get the plastic piece out. I believe I may have short-circuited something when the key kit something inside there. The cigarette thing doesn't seem to work anymore.
The point of this thread is that the radio does not work anymore. When I turn on the PWR ****, nothing is ON. All I see is a blinking red light (Anti-Theft). I'd figured by messing around with the cigarette thing, I may short-circuit and the radio reset just like if the battery of the car is disconnected. I would expect to see the word CODE displayed when I turn on the unit; however, the display is blank. I tried entering the five-digit code button nothing happened.
Is my radio dead? Thanks in advance! If indeed it's dead, anyone have an OEM radio for sale?
Old Mar 20, 2006 | 12:24 AM
reds2k1
Default RE: 94 Honda Accord Radio/Cassette...Does Not Turn On...Need Help!
BTW, I've also tried disconnecting the battery and also unplugging the cable from the back on the head-unit. Still the unit does not turn on. When I unplug the calbe from the head-unit and then re-attach it, I can hear some mechanical noises from the cassette mechanism. I think the unit is getting power though.
Thanks!
Old Mar 20, 2006 | 02:53 PM
sir_nasty's Avatar
Have you checked your fuses? I had a friend run into a very similar issue when a penny fell into the cigarette lighter... It sounds to me like your constant power is running but the other fused link is shot... check the fuses and let us know!
Old Mar 20, 2006 | 08:52 PM
reds2k1
Before I attempt to check every single fuse, would you know what fuse and where (engine compartment or under-dash) to check?
Thanks!
ORIGINAL: sir_nasty
Old Mar 20, 2006 | 11:49 PM
reds2k1
Indeed, it was the fuse (radio/cigarette) under the hood. I'd forgotten all about the fuse boxes under the hood. Initially, I only checked the one under the dash.
Thanks!
~Liquid
Apr 4, 2013 07:23 AM
bcasey
Feb 23, 2013 06:10 PM
jrdew
Jan 16, 2009 11:15 AM
