New Sub! keep_hope_alive
Old Jul 31, 2010 | 01:51 PM
19Accord97
Originally Posted by keep_hope_alive
a 2 ohm DVC would be wired in series for a 4 ohm mono load. I'd go with MB Quart over Tidal.
also, pick up a sub grille while you are at it...
So this would look like:
+ Left channel goes to + on 1st voice coil
- Right channel goes to - on 2nd voice coil
Wire between the - on 1st voice coil and to the + on the 2nd voice coil?
According to the amp specs, it would be getting 800 watts? Which is far to much for either sub. However, I had my Volfenhag wired as I just explained and it too was 500watt RMS and I ran it for a few years like that.
Don't worry, I have a sub grille in my watch list on eBay!
Old Jul 31, 2010 | 11:06 PM
keep_hope_alive's Avatar
Audiobahn is overrated, so don't worry about 800W. Music is dynamic and you always want more power available then you intend on using.
you have the right idea with the series sub wiring.
Old Aug 1, 2010 | 12:12 AM
19Accord97
So any guess as to what it actually would be putting out?
I can't believe they rate it at 800w. Like I said, I had my Volfenhag hooked up to it for a loooong time which was rated at 500w rms like the MB Quart. I just don't want to ruin an expensive subwoofer.
So if I have the gain (or Level on my amp) turned 1/2 way or less I should be alright? Does that mean I can turn the subwoofer control on my stereo to level 10 of 10? I usually have it on +2 but once every couple months I will really crank it.
Old Aug 1, 2010 | 08:10 AM
you need to revisit your gain settings. they should be re-adjusted per this:
http://forum.sounddomain.com/ubbthre...ge=1#Post65167
This link will explain how to properly set your gain to obtain a desired power output.
Old Aug 1, 2010 | 09:21 AM
19Accord97
Gotcha!
This should be done after the break in period, correct?
Old Aug 1, 2010 | 12:32 PM
no, it should be done before you ever connect a sub/speaker to an amp. for break-in; set the amp output power to about half the sub's rated RMS power. After break-in; feel free to set the amp output to the full RMS power rating of the sub.
Old Aug 1, 2010 | 06:18 PM
  #17
19Accord97
Just ordered it so we will see how it goes!
Thanks again for your help!
Old Aug 3, 2010 | 04:13 PM
  #18
19Accord97
Itll be here Friday! Can't wait! I was gonna order it off eBay, then realized the seller was WoofersEtc!
For future reference, it is the same price on their site or on their eBay account, BUT they only offer a 9 month warranty if you buy if through eBay vs a 1 year warranty if you buy it off their site. I got it off their site.
Old Aug 4, 2010 | 12:15 PM
  #19
wooferetc is a nice online retailer with a huge selection.
Mar 16, 2013 04:52 PM
ShadowWolf9
Apr 19, 2011 12:19 AM
keep_hope_alive
Apr 8, 2011 03:01 PM
christian2000accord
Apr 26, 2009 09:53 PM
status
Feb 7, 2009 01:26 AM
