A new user has some questions about sub/amp setups
Old Feb 9, 2011 | 07:52 PM
  #51
keep_hope_alive's Avatar
Just have your battery and alt load tested at a local auto parts store. A good starting battery is important. A volt meter in the dash is also good to have. Below 12volts is bad and a sign to turn it down.
Did you verify sub impedance and amp impedance?
Old Feb 11, 2011 | 04:34 AM
  #52
ShadowWolf9's Avatar
The sub impedance confuses me a bit. It's rated as such: 1.8 Ω / coil (3.7 Ω in series)
While the amp is rated at 1000w @ 2ohms with 1500w @ 1ohm
edit: Would something such as this: http://www.amazon.com/Equus-3721-Bat...=pd_sim_auto_1 be suitable to monitor the voltage?
Old Feb 11, 2011 | 10:48 AM
  #53
you will wire the voice coils in parallel for about 1 ohm mono load on the amp.
yes, that volt meter will be fine, won't tell you voltage at the amp, but will tell you battery voltage.
Old Feb 20, 2011 | 11:07 AM
  #54
Seeing how the dealer says it's only $20 more, I'd love to go for the 15" model of the sub, but I don't know if my trunk will be able to fit it if I go ported.
The new accords have 14.7cf of space, but its shape is so irregular I don't think I'd know until I put it in. For a ported enclosure the sub specs are 3.0 - 5.0 CF yet I believe that's airspace wise?
Old Feb 20, 2011 | 09:02 PM
  #55
That is a huge box. Difficult to fit due to height. You want 18" of height to fit a 15 vertically. Or do IB like I did and save the enclosure.
Old Feb 25, 2011 | 10:52 PM
  #56
Decided to go with the 12" to avoid any issues. I also just purchased a Sundown Audio SAZ-1500D for a great price.
It was a bad idea to go for 4awg wire at first since it didn't leave much room for upgrading and I plan to remove these horrible stock mids eventually anyway. Since I would need new fuse holders an whatnot, would this power kit suffice? http://www.amazon.com/PSK00B-Power-S.../ref=de_a_smtd
I'm trying to find a good shop around my area to work on sound deadening and whatnot as well. No Idea how to get the most output out of my sub either. I'd love if I could get it pushing out towards the cabin from the rear deck somehow.
Old Mar 1, 2011 | 11:51 PM
  #57
Still a ways off, but I was plotting the speaker upgrades as well. These bad boys caught my eye: http://www.woofersetc.com/p-9626-esk...nt-system.aspx
Not sure where I'd have the shop put the midrange exactly.
Edit: Also, I think I'm going to upgrade to a Stinger 1/0AWG kit. I have about $130 worth of Amazon credit I wanted to splurge on deadening material. I remember you mentioned a cheap yet effective brand in another thread. I definitely plan on using some on my front doors, but is it worth it to do the trunk as well?
Old Mar 2, 2011 | 09:46 PM
  #58
for deadening - look for Raammaudio BXT II. awesome stuff.
I like that 3-way package and the price is amazing. it is in-line with the ESK product. I will say this - the midbass and midrange are great. The tweeter is SUPER bright. you don't aim them at you. I would buy that set and replace the tweeter. Nice find! You won't get a better set at a cheaper price.
The 4" should go in the kicks, aimed at the dome light. make that happen and you'll be very happy.
Old Mar 3, 2011 | 12:06 AM
  #59
Thanks for the reply! Any tweeters you'd recommend that could fit snug in the stock location?
Old Mar 3, 2011 | 06:44 AM
  #60
Stock tweeters are usually too small for my liking, most are 3/4". I like 1-1/8" silk dome tweeters. There is usually some modification to the factory mount, I don't like pu ttinng tweeters behind stock grills either, too restrictive.
With s 3-way you don't need as large of a tweeter since you use a higher crossover point. But then you can't use them as a 2-way as effectively. So you can run a 3/4" tweeter if you stay with the 3-way.
Pates Express sells tweeters:
Morel
Dayton Audio
Vifa
You just need to be careful that you replace the tweeter with the same impedance. If not, you need to run it active or use a separate crossover.
