No Factory HeadUnit Illuminations
Old Sep 6, 2007 | 08:05 PM
pham9006's Avatar
Default No Factory HeadUnit Illuminations
I have an 2003 honda accord coupe. I just finished installing an aftermarket headunit with the new bottom mount installation kit. Which means the bottom pocket was taken out. Well, everything works great except the illumination on my old factory headunit. For some reasons the lights will not appear and i need to be able to see the climate control at night time. All my other interior lights work fine. What can i do? It really makes it unsafe to drive at night if i am messing and gussing which buttons are which the the factory headunit. I was thinking about buying another harness to hook back into the factory headunit and only connecting the power wire into the new(working harness)...
I NEED HELP
Old Sep 7, 2007 | 04:44 PM
sir_nasty's Avatar
Default RE: No Factory HeadUnit Illuminations
I'm assuming that you removed your stock headunit? Or did you just install an aftermarket one below the stock one?
Old Sep 7, 2007 | 11:32 PM
pham9006's Avatar
Wow, i solved the problem. thanks anyway sir_nasty. No i installed another hu under the factory hu. What i did wrong was i forget to attach the male connection back into the factory hu, which allowed illumination back to the factory hu.
solved the prob myself.
thanks everybody
Pellicci21
Dec 26, 2011 11:31 AM
WhiskeySlick
Aug 1, 2011 03:31 PM
pham9006
Sep 13, 2007 09:04 PM
t00fatt
Dec 25, 2006 08:12 PM
ivrex
Nov 19, 2006 11:29 PM
