Peel & Seal?
Old Sep 11, 2012 | 07:06 PM
94ex915's Avatar
Almost A Senior Member
Default Peel & Seal?
Has anyone ever tried peel and seal for a sound deadener? I have heard mixed reviews about it but people have said it does work. Not looking to spend hundreds on dynamat.
Shop Peel & Seal 6" x 25' Mastic Roof Coating at Lowes.com
Old Sep 11, 2012 | 07:41 PM
I suspect it will work to some extent. Where do you place it besides the wheel wells? Probably need to clean wheel wells and other places w/ water blaster before applying.
If in northern area, corrosion under wrap may be a problem if you coat body steel.
Old Sep 11, 2012 | 07:43 PM
94ex915's Avatar
Doing it for my subs actually. Getting a lot of vibration in the trunk and where my rear speakers are.
Old Sep 11, 2012 | 09:09 PM
MacLeod's Avatar
NO! Not worth it by a long shot. I tried it once several years ago looking for a cheap alternative to Dynamat and the smell of asphalt nearly killed me. This stuff is made to be used on a roof, not in a car.
Dynamat is more expensive but the stuff is the best. It wont asphyxiate you, it wont peel off after a year or two and its very dense so a little goes a long way. You dont have to cover the entire area with it. You can use it in spots and itll work very well. Think of it like the bell youd ring for service at a motel. If you ring the bell, itll ring for a long time. If you just touch the bell with one finger and ring it, itll go CLUNK. Same thing here. You dont have to cover your entire rear deck in Dynamat to get it to stop resonance - just a good sized chunk used here and there can do a lot too.
Old Sep 13, 2012 | 05:20 PM
keep_hope_alive's Avatar
No asphalt products in a car. They do not belong there. Their fumes have carcinogens. They aren't even rated to be in a building.
You can get cheap butyl products that have some benefits. But they may not provide actual damping which requires viscoelastic and elastomeric properties.
Cody Is Cool
Nov 28, 2016 10:02 PM
basket_case
Aug 7, 2012 08:46 PM
drumdoctor
Jan 16, 2012 09:53 AM
19Accord97
May 22, 2010 08:57 PM
