Removing Stock Car Deck
Old Dec 4, 2008 | 10:04 AM
kyler
Default Removing Stock Car Deck
Just wondering whats the best way to remove the stock deck on a 92 accord. not sure where to start. thanks.
Old Dec 6, 2008 | 01:22 PM
smaglik's Avatar
Default RE: Removing Stock Car Deck
look for screws and clips...and be gentle!
Old Dec 13, 2008 | 08:49 PM
bmwproboi05's Avatar
ok. well on the side of the center concle their are four screw i belive two on each side. remove the four screw. pull your hand break up. and then wiggle it off. you might have to put the car into nutral useing that shift lock release thingy. then pull it up slowly.
from their pop off the ash tray. then remove the screws in their. becarefull their is a tricky one all the way in its on top so youll barely see it. so dont yank the crap out of it. an the other screws at the bottom by the transmision an wala. you should be able to remove the radio an the ac part.
you might want to use a small 8mm rachet to get the bolts out. if you need any help let me know
jamola10
Jan 14, 2010 12:05 PM
Sled14
Oct 31, 2008 06:41 PM
zubes
Oct 20, 2006 05:36 AM
jdinh127
May 31, 2006 09:14 PM
Rus
Oct 6, 2005 05:00 PM
