Removing Stock Car Deck
ok. well on the side of the center concle their are four screw i belive two on each side. remove the four screw. pull your hand break up. and then wiggle it off. you might have to put the car into nutral useing that shift lock release thingy. then pull it up slowly.
from their pop off the ash tray. then remove the screws in their. becarefull their is a tricky one all the way in its on top so youll barely see it. so dont yank the crap out of it. an the other screws at the bottom by the transmision an wala. you should be able to remove the radio an the ac part.
you might want to use a small 8mm rachet to get the bolts out. if you need any help let me know
jamola10
Jan 14, 2010 12:05 PM
zubes
Oct 20, 2006 05:36 AM
