The right sub
Old Mar 12, 2006 | 11:38 PM
Green_Accord's Avatar
Default The right sub
Hi guys ..
I want to buy a sub woofer but im not sure which one will be the right one for my sedan.. Like we all know if i get the powerful one, it will rattle the trunk and if it isnt powerful enough, it will just be a waste of money.. any advices are appreciated ..
Old Mar 13, 2006 | 02:44 PM
sir_nasty's Avatar
Default RE: The right sub
the biggest thing in selecting the right sub/box is what kind of music do you listen to? I have an Eclipse 12" in a sealed box for Punk/Metal or basically a fast hard bass roll... I just use a Kenwood 400W amp with it and I'm plenty happy... But if you listen to rap or something with a deep drawn out bass then I would suggest a bandpass box or a shelf ported box I've heard is a nice sound... I put a shelf ported box in my car with a slightly different sub and then swapped it out with my sealed box and noticed a difference but not a whole lot... so basically it comes down to what do you want to do/listen to? comptetion grade or ??
Old Mar 13, 2006 | 03:58 PM
lightshow's Avatar
mmmm well you can get a powerful sub and it wont rattle your trunk. if you dont dynamat your trunk, any sub you get will produce distortion ranging from barely noticable to downright horrifying. some people dont mind bad sound.... actually a grip of people are perfectly happy with it. a ported box will give off a boomier sound, a bandpass box will give off an amplified boomy sound in the 60- 90 hertz range and a sealed box will give off a tighter cleaner sound, but requires more power to run.
Old Mar 13, 2006 | 09:34 PM
marbro's Avatar
side note, in a sealed case you can change the sound by adding polyfill often you can get deeper bass by doing that
Old Mar 13, 2006 | 10:38 PM
I have a DVD player in my dash so i really want to hear a clean and tight sound. I guess i have to go with a sealed box then .. thanks for your advices guys .. u guys r the best
Old Mar 14, 2006 | 01:53 PM
sir_nasty's Avatar
Another Side Note.... I decided to take the same sealed box I have and drilled a 2.5" port in it at one point.... I never put in the plastic port but my sound went to @#$@# for obvious reasons....
Old Mar 14, 2006 | 07:15 PM
lightshow's Avatar
the polyfill will make the bass much much deeper
Old Mar 15, 2006 | 08:02 PM
cool sir_nasty..
to Lightshow, it definitely makes the bass sound deeper..
ryanpitts1
Jun 29, 2014 04:47 PM
clash69
Aug 9, 2006 12:39 AM
henry8060
Aug 5, 2006 03:20 PM
liltwevie3
Apr 5, 2006 08:22 PM
zelseman
Jan 13, 2006 03:30 AM
