speakers HELP!!
Hello New Member...
Thank You for joining up in the forums..
You posted your question in the right forum, so your ok..
Have yourself a Merry Christmass...
[IMG]local://upfiles/22/EC511EA7B1904F09AE8F4F3974A6B6DC.jpg[/IMG]
in the trunk, if you lay down and look up you'll be able to find the clips for the covers. Push those up and the covers will come right off. Then take an 8mm socket and the factory speakers will unplug from the little white harness. poof you're done
yep the ones in the back are easy to replace, the ones in the doors are the weaker ones and are a little harder to replace. youll have the take the door panel off. no biggie at all, which speakers are you planning on replacing? o and welcome to the board.
lightshow
lightshow
you know, i havent taken the door panel off on a new accord, but it should work about the same way as the others.
there are some phillips screws that you have to remove look for all of them. there will be one in the door handle and possibly in the armrest, and maybe one more lurking around somewhere. you have the then remove the door handle. push it forward and then pull it out about an inch. you have to remove the electrical plug and the metal bar that is attached to it. then the rest of the door is attached with clips. just take a big flathead and pry up EXACTLY where the clip is. ther may be a couple more plugs for the door lights and stuff.
Fat Ryan
Oct 25, 2007 12:25 AM
AdamBl
Dec 26, 2006 10:13 PM
cellstop2
Jul 22, 2006 11:23 AM
