need help removing front 6.5" speakers!
Old Jul 9, 2006 | 02:21 PM
leviq
Default need help removing front 6.5" speakers!
To anyone who can help, I have a 99 coupe and began removing the door cover to access the existing speakers for replacement.
I removed two screws, one located in the handle (used to pull the door closed) and the other located right below the chrome lever (for opening the door).
I popped open various rivets along the door but not there's something within the chrome lever keeping the cover from coming the rest of the way off.
I tried removing the plastic piece around the lever and tried pulling and twisting the lever to remove it from the door but no luck.
Could someone please advise how to remove the door cover the rest of the way? Many thanks!
Old Jul 9, 2006 | 03:26 PM
marbro's Avatar
Default RE: need help removing front 6.5" speakers!
for the inside door handle on the back of it theres a white plastic bracket holding a rod into place, you can turn that plastic to remove the rod from the door handle, or you can pull the whole inside door handle toward the front of the car, it should have about a half an inch of play just like the normal door opening with the handle and you can rotate the handle through.
Old Jul 9, 2006 | 07:15 PM
purify's Avatar
I'm pretty sure that you have to pull up on the door panel to get it off. I do this with the window down. Also double check for extra screws. My prelude has 3 screws. But you've got the right idea.
Old Jul 10, 2006 | 07:52 AM
YeuEmMaiMai's Avatar
there are also clips around the edge of the panel and one clip in the upper right corner of the door panel
Old Jul 12, 2006 | 06:09 PM
DaveMason
I just bought a Honda Accord EX-L V6 and the sound is terrible. Is it just my car or Honda has the worse sound system ever?
What speakers do you guys recommend for that model?
Old Jul 12, 2006 | 07:21 PM
jtf4619's Avatar
how much are you looking to spend????? Do you plan on putting an amp on them later????Some more details please!
Old Jul 12, 2006 | 07:32 PM
sTeVo!'s Avatar
read through this...
how to pull a door panel - 99 accord
good luck.... [8D]
hyrumbradshaw
Apr 12, 2014 03:17 PM
k24vtec
Jan 23, 2009 02:20 PM
mbogosia
Jun 12, 2008 07:26 AM
Accordcurious83
Apr 16, 2008 01:39 PM
Fat Ryan
Oct 25, 2007 12:25 AM
