Subs to Factory Stereo
Old Mar 31, 2014 | 01:07 PM
94ex915's Avatar
Almost A Senior Member
Default Subs to Factory Stereo
Had a question on how to install subs and amp to a factory head unit. The car is a 2012 Mazda 6. Wondering what I what need to do this and if it is possible.
Thanks in advance.
Old Mar 31, 2014 | 08:40 PM
neophyte's Avatar
You will need:
Line out converter
RCA cables
power and ground wire
some wire for a remote
amplifier
subwoofer
box.
completely doable and fairly simple.
Old Mar 31, 2014 | 09:08 PM
94ex915's Avatar
Originally Posted by neophyte
You will need:
Line out converter
RCA cables
amplifier
subwoofer
box.
Ya I was reading on the line out converter but someone had said a bass restoration sound processor would be a better option. Any thoughts on that?
Old Mar 31, 2014 | 10:32 PM
keep_hope_alive's Avatar
Audio Control has a series of processors with bass restoration. If your Mazda has a multi-speaker system then you either need to tap the full range signal on the largest drivers or use a summing device that combines all of the speaker outputs into a single pair.
Old Apr 1, 2014 | 05:48 PM
94ex915's Avatar
So can I use the processor rather than the line out converter or would both be needed?
Old Apr 1, 2014 | 08:03 PM
neophyte's Avatar
for the majority of them you will need both. the bass processor is a nice thing to have. any kind of crossovers, processors, equalizers, will add to a stereo if you set them up properly. it is just usually people are looking for the cheapest route when they do not give a budget which is why I did not mention it.
Old Apr 1, 2014 | 08:32 PM
94ex915's Avatar
I will probably just go with both then. What is a good processor?
Old Apr 1, 2014 | 10:01 PM
neophyte's Avatar
how much of a budget do you have for the processor?
this is a decent one that wont break the bank.
nvx bass reoconstructer
but there are better ones out there.
and this one does not require the line out converter. you can use high level inputs. but it is pricey.
audiocontrol
Old Apr 2, 2014 | 04:39 AM
94ex915's Avatar
audiocontrol
Budget is not much of an issue since I already have a sub and an amp. I'm going to look into this some more. Might go ahead and just go with the line out converter for now and see how everything works out. Thanks.
griffulas
Feb 3, 2012 10:17 AM
atlj007
Feb 22, 2010 05:42 PM
accord2k1
Aug 27, 2007 02:39 PM
Maximo
Jul 30, 2007 05:48 PM
cclingma
Jan 7, 2007 01:30 PM
