Suggestion on Honda 2003 Accord EX CD Player Option
Old May 9, 2012 | 12:52 PM
asalmank's Avatar
Default Suggestion on Honda 2003 Accord EX CD Player Option
Hi,
I just bought a used 2003 Honda Accord EX. Unfortunately, owner changed the original 6 CD changer(Ex model) to a factory made 2003 Accord LX single CD changer. It works but it can't be controlled through the steering controls and that's annoying at times.
I have two questions on this:
  1. How cheap a used EX model CD changer would be? Besides EBay is there any place I can look for?
  2. Secondly, Is there any other private stereos which I can install in dash and that can controller by steering controls?
Thanks in Advance!
Old May 9, 2012 | 01:12 PM
Tyler Joyce's Avatar
Most stereos you buy today have a wire specifically for steering wheel controls. I would pull that stereo out and see if the wire is even hooked up. Its possible he just didnt hook it up.
Old May 9, 2012 | 02:43 PM
crispin's Avatar
2) YES many aftermarket radios can be setup to work with the steering wheel controls.
For you I recommend going to www.crutchfield.com they will advise you with not only what radio will work for you they can also provide you wire harnesses and radio mount that will make installing everything yourself rather easy.
Old May 9, 2012 | 03:10 PM
asalmank's Avatar
Thanks Tyler and Crispin. I have checked with dealer and somehow this LX factory stereos, can't be controlled through steeing and thus doesn't have a cable.
I will definitely look into the crutchfield and hopefully would be able to use my steering controls for the new player.
Regards,
Salman
Old May 9, 2012 | 09:59 PM
keep_hope_alive's Avatar
The steering wheel interface I use is the PAC SWI-Jack. It is programmable for several makes/models.
You just need a HU that is steering wheel control capable, and to get the mounting kit and wire harness adapter.
Old May 11, 2012 | 09:53 AM
asalmank's Avatar
Thanks hope!
I appreciate the feedback. I searched the PAC-SWI jack and it seems good. The problem is the Honda Unit which is steering wheel control capable. I am searching on ebay and if find one in a cheap price, I will buy one.
Regards,
Salman
Rilex
Aug 14, 2015 12:04 AM
rak007
Jan 12, 2012 11:49 AM
furrynyy23
Oct 9, 2008 12:19 PM
Sinecure
Oct 27, 2007 02:20 AM
BlackTL
Feb 8, 2007 04:17 PM
