Suggestion for MP3 player hookup to 05 Accord
Old Oct 5, 2008 | 03:44 AM
furrynyy23
Default Suggestion for MP3 player hookup to 05 Accord
I have 2005 Accord with the OEM 6 CD changer and XM.
I want to hookup an MP3 player to the unit without using an FM transmitter. I checked Honda accessories and saw only their IPOD interface and the single CD unit for like $400 that plays MP3/WMA. Is there anything good out there I can do to connect the audio output jack of the MP3 player directly to the OEM radio - or even better, something that will accept a USB input like a flash drive?
I am not good with tearing apart the unit, dash, electronics, etc... so something for idiots that is simple to do with instructions would be ideal.
Thanks.
Old Oct 5, 2008 | 11:39 AM
t00fatt's Avatar
Default RE: Suggestion for MP3 player hookup to 05 Accord
If you don't want to lose your XM your going to have to get a direct connection FM transmitter. I've never heard one, but people here (falkore I believe) says they sound good and nothing at all like an over the air transmitter. It basically connects directly to the antenna. If you are ok with losing the XM then you have many more options. The only AUX port on the headunit is used by the XM if installed. So you would have to lose XM to do what you want. I really recommend replacing the OEM headunit, the audio quality is horrible and has no power and I had the "premium" audio system.
Old Oct 6, 2008 | 09:40 AM
falkore24's Avatar
The wired transmitter I had was for SIRIUS, but I believe there are similar units out there for MP3 players .... it would have to take a battery though because it needs a tiny bit of power to interrupt the antenna radio signal. Mine got the power from the sat sattelite radio.
Old Oct 9, 2008 | 11:26 AM
furrynyy23
I don't want to lose XM. I actually listen to it the most. Maybe that would change with MP3/USB connector.
So changing the OEM headunit...how much of a pain is it? I am an engineer by training (chemical) so I can understand technical, use a screwdriver, wire cutters - but electronics is not my things. I can replace components in a computer but I can not rewire my house. Am I looking at a 10 hour project that I could easily screw up?
What type of headunit would you recommend? I would like to have one that has all the features I have (AM/FM/CDx6/XM) and add MP3/USB connector. Nav/DVD not so importat. Being able to play MP3/WMA, etc... from CD would be nice.
Am I best going to an installer for this?
ORIGINAL: t00fatt
Old Oct 9, 2008 | 12:19 PM
t00fatt's Avatar
It's really quite easy to install a new radio. You just have to buy a $150 kit to even be able to install a radio in your car. The HVAC controls are built into the stock radio, so the kit is expensive because it has HVAC controls built in. I really recommend doing it though, you will get an extreme increase in sound quality. I replaced my stock headunit after only 3 months of having the car. I couldn't stand the AUX interface because the sound was marginally lower than then the CD player audio, which wasn't loud enough to begin with. To wire the radio all you need is an adapter for your car, which will plug into the plug that goes to the stock radio. This adapter has wires, already stripped and marked. So all you have to do is match the wires from the new radio to the wires on the harness adapter, it's really quite simple. What is important is making sure you have a soild connection, I like to solder and heatshrink the wires. But you can use crimp-ons you just need to make sure there are tight, and don't use pliers to crimp them as I've seen people try to do.
hazeces
Aug 25, 2013 10:25 AM
asalmank
May 11, 2012 09:53 AM
HawkeyePierce
Feb 23, 2009 11:17 AM
M.I. Evil
Apr 25, 2007 03:28 PM
GodMachine
Jun 4, 2006 10:07 PM
