system blowing spark plugs?
Old Aug 7, 2012 | 03:40 PM
wiSeGuy626's Avatar
Exclamation system blowing spark plugs?
i have a sound system running off a 1200 watt amp 12' sub pioneer 3000watt and running new speakers for the doors as well pioneer but I just realized with my friend after I installed my hid light kit that my spark plugs are going out and we have came to the conclusion it’s because of my system pulling too much power and actually causing my hid lights to go out and also my system to shut down any answers or anyone gone thru this problem?
Old Aug 7, 2012 | 07:33 PM
keep_hope_alive's Avatar
the system will not cause failure of HID or spark plugs.
the system can shut off due to a drop in voltage. what is the battery voltage when this stuff shuts down?
a drop in voltage can be caused by several factors:
1. poor grounding and wiring connections. you can post pics of your connections at the battery and amp for power and ground for evaluation.
2. weak main battery. how old is it? what voltage does it sit at when the car is off? has it been load tested? has the alt been load tested?
3. ELD. the ECM monitors ignition load through the ELD and will shut off the alt field current when the load is low. the ELD does not see the extra sound system.
faran
Jul 25, 2013 08:48 AM
sirtwist2
Sep 24, 2012 01:36 AM
BHoward711
Apr 12, 2010 08:57 PM
marbro
Feb 18, 2006 12:17 AM
hotrod20
Dec 4, 2005 11:04 PM
