Trying to install amps and subs 95 accord
Old May 9, 2008 | 06:50 PM
BlackZ
Default Trying to install amps and subs 95 accord
I was trying to hookup 2 mosfet amps and 2 jensen subs and wired it all, but the amp doesnt turn on, i couldnt find a remote wire on my pioneer DEH-2700, anybody kno what i could do?
Old May 10, 2008 | 09:12 PM
MacLeod's Avatar
Default RE: Trying to install amps and subs 95 accord
You can run the remote turn on lead to your fuse box. Wire it up to something that comes on with the igintion. I use the radio fuse cause its small amperage. You dont need a lot of juice just a small signal to tell the amp to turn on.
Old May 12, 2008 | 10:36 AM
ancientoneuk
You can use the auto aerial lead I found on some installs and hook the remote amp wire to that and it will switch it on, my Hyundai has that rigged on a Mutant Amp/Sub setup and works fine.
I think its a yellow wire but check first.
Old May 12, 2008 | 09:23 PM
tru_44's Avatar
u could also run a remotewire to 12+ power wire,so the amp would turn on. Then add a kill switch so that u could tun it off.
Old May 25, 2008 | 07:25 PM
Flatline1121's Avatar
You should run a remote wire to the back of the radio following the signal(RCA) wires and wire it into the RED wire. The red is the "switched" power that turns on when you turn the car on. and this is what certified techs do... let me know how it turns out.
Old May 27, 2008 | 10:41 AM
falkore24's Avatar
The remote wire is blue, sometimes with a white stripe ..... the HU has it, just find it on the wiring diagram that is stuck on top of the unit.
Old May 27, 2008 | 11:43 AM
finch13's Avatar
ORIGINAL: ancientoneuk
Most "modern" headunits only utilize the power antenna wire when the radio is being used. The amp will shut off if you switch from "Radio" to "Disc" or "iPod" etc.
Usually the deck has blue for power ant. and blue/white for amp, or vice versa. If you have no luck with that, just tap into the red or yellow ignition power, NOT the "always hot" wire or you'll drain your battery from having the amp on all the time.
Tuner Jr.
Aug 7, 2013 07:35 PM
btort1
Apr 15, 2012 10:42 AM
Mikes Machine
Feb 11, 2008 06:24 AM
cucubing
Aug 16, 2007 11:56 PM
drewdin
Jul 4, 2007 10:08 PM
