Tweeter Cover Removal
Old Dec 12, 2006 | 05:07 PM
Crux
Default Tweeter Cover Removal
Hey Guy's, Anyone know how to remove the tweeter covers in the dash on a 2005 Accord EX-L? I' m apprehensive about digging away on them and breaking them. So I'm hoping someone here has done this before and can help.
Thanks
Old Dec 13, 2006 | 01:54 PM
dadams09's Avatar
Default RE: Tweeter Cover Removal
i just did this 2 weeks ago and customly put in polk momo tweeters.,... its simple... get a flat screwdriver and lift up the front of it ... do it gently so you dont but a crease in the dash there are 2 spring clips in the front that will pop out and then pull the grill towards you so that the back releases... there are no spring clips in the back but there are clamps that slide under the dash in the back... if you need pics let me know and i'll take some and send it to you. Good luck
Old Dec 13, 2006 | 08:39 PM
Crux
Cool! Thanks alot man that really helps. I'm gonna give it a try and I may ask you to post those pics depending how it goes, but sounds easy enough.
Old Dec 14, 2006 | 06:11 PM
chrislloyd
i was about to do the same thine... do you know where the wires run to?? i need to hook them up to a crossover... dont really need to pull new wire for a tweeter.
Old Dec 15, 2006 | 03:27 PM
dadams09's Avatar
they run down to the headunit.. but i would just run new wires that;'s what i did you can run a thicker and better gauge wire and it will sound clearer and better because it carries a stronger signal...
dadams09's Avatar
dpclarkjr
Aug 30, 2009 06:25 PM
accordn00b
Jul 10, 2009 11:54 AM
steve123
Apr 6, 2008 06:46 PM
falkore24
Oct 8, 2007 01:03 PM
Cyphin6
Sep 5, 2007 08:49 AM
