Using a factory stereo with amp
Old Dec 15, 2014 | 08:12 PM
studders's Avatar
Default Using a factory stereo with amp
Hello, I have a 2003 Honda accord ex and I was just wanting to know if it is possible to hook up a amp and subwoofers to the factory unit? I don't want to do anything big just a small amp and subwoofers to blast my county music. I have hooked amps before on factory units by running the power straight to the battery with a toggle switch next to my seat to turn it on and off, lol. (Rigging stuff up). But if this is possible please share your information with me with a quick rundown. Thanks
Old Dec 15, 2014 | 11:09 PM
keep_hope_alive's Avatar
you don't need the toggle switch these days - we use line output converters (LOC) with an auto turn-on feature (like home sub amps). the Audio Control LC2i is the more popular solution and includes bass restoration and auto turn-on.
you'll still run power wire fused at the battery and route through the fire wall (with a grommet). you'll need to tap the rear speakers for the signal to the LOC.
that's pretty much it. tap the power wire for LOC power or run an ignition wire for the LOC (to ensure it shuts off).
it's compatible with any amp and sub combo you want.
Old Dec 15, 2014 | 11:11 PM
LC2i 2ch Line Out Converter with AccuBASS(tm) and Subwoofer Control
http://rs.audiocontrol.com/company_3...3-13Update.pdf
the optional dash level control remote would be a nice addition so you can control the level of the sub without having to use the fader.
note that by tapping the rear speakers, the fader will affect the sub signal. fade to front and the sub signal gets weaker.
accord2k1
Aug 27, 2007 02:39 PM
Maximo
Jul 30, 2007 05:48 PM
pyaarawala
Jun 28, 2007 08:59 PM
cclingma
Jan 7, 2007 01:30 PM
