Want to upgrade sub and add an amp 2013 accord.
Old Jun 30, 2013 | 09:37 PM
  #21
neophyte's Avatar
adding new speakers with out an amp is a waste of time, honestly. an amp will help. however with the amp you are going to have problems with the anc mics. they will need to be disconeccted. chances are you are getting alt wine through your speakers. if everything on the car is stock probably caused by a loose connection of the factory grounds or you have corrosion on your terminal causing a poor ground.
Old Oct 25, 2013 | 02:10 PM
  #22
dolfanpaul's Avatar
Exclamation ANC unplug
There is a post in which the owner of a 9th gen accord. ( 2013 model year ) discussed how to disable the Active Noise Cancellation on a 2013 Accord. I have a 2013 Accord Sport and used his advice and went through the passenger side kick panel ( the one closest to the radio, so it would be right next to the passengers left foot.) Just trying to help anyone out, because it helped me. You can pull back the kick panel enough ( starting on the end closest to the engine. or front of the car )... Pull the panel back and shine a light into the space behind the radio. You will see a plug with a lot of wires on it. The ANC module is light gray or some would say white in color. Unplug that plug by releasing the tab on top of the plug. I did this and everything still works. Bluetooth, hands free phone, and all controls. I then installed an aftermarket sub, woofer, and upgraded the speakers. Turned out awesome absolutely no feedback from the sub, totally silent ...All you hear is the music... If you are going to upgrade to the component speakers. ( front speakers with tweeters. ) You will have to get 2 new tweeter panels because there is not enough clearance with the stock Accord Sport panels. ( these are the small panels closest to the mirrors, obviously on the inside of the car. ) The panels you have to get are from upgraded accords that come with the factory tweeters. They are only $25 bucks each and well worth it.
Old Oct 27, 2013 | 07:26 PM
  #23
keep_hope_alive's Avatar
thank you!
Old Apr 21, 2025 | 03:29 PM
  #24
witthuhna's Avatar
Here is a link to a helpful video that shows how to turn off factory EQ or it just adds a flat EQ. I know this thread is old and I'm not sure if anyone else shared this previously. The thread helped me gain clarity about my amp so I hope this is helpful. I personally like the flat EQ and prefer it since my speakers are upgraded.
jcarver6
Jul 15, 2013 01:57 PM
GT2013EXLTO
Apr 10, 2013 11:11 PM
apatel41
Jun 27, 2009 08:31 PM
karb0nk0py
Sep 14, 2007 11:50 PM
dalondono
Aug 25, 2007 06:50 PM
