Yo T00fatt i gotta couple questions
Old Jan 19, 2009 | 01:49 PM
AccordLXMaster's Avatar
Default Yo T00fatt i gotta couple questions
remember my setup well im still saving so it hasnt got any better....but thing is ive been reading around and it seems i dont have the proper wire for my setup....i think i have about 8 or 6 gauge wire.....and thats including ground..power..and sub wire.....and also my other question would be (but i think i kno the answer)...i threw a pioneer TS-somethin..lol.its blue..12" the one with like 150rms and 800max....well i aded that to the setup and i actually push it to the limits and it does fine...but am i damaging that sub and will it also underpower the kicker to the extreme???
Old Jan 19, 2009 | 01:52 PM
finch13's Avatar
Default RE: Yo T00fatt i gotta couple questions
opcorn: + :couch:
Old Jan 19, 2009 | 01:54 PM
Tippman7641's Avatar
i had that sub, and it was easily over powered all the time, and yes it will uner power the kciker, and over power the pioneer
Old Jan 19, 2009 | 01:57 PM
mind you that the pioneer has been in the setup for about a month now and still no problem
Old Jan 19, 2009 | 02:02 PM
ORIGINAL: finch13
opcorn: + :couch:
ill join yay haha
if they flutter at all this is know as sub strain, which means they are being over powered, sometimes this sound sounds like something is lose in your car
Old Jan 19, 2009 | 02:11 PM
t00fatt's Avatar
When a sub is being over powered and is clipping it doesn't have to break right away, it is getting damaged. And running that sub is not giving the kicker the power it wants, it may sound better because you have a circular sub hitting those highs a bit more, but your wasting power running that second sub. If you don't care about that sub, and think it sounds better I see no reason not to just leave it like that. But that sub WILL blow, 150w is not much power what ever your feeding will burn the coil, or bust the spiders eventuality. How many watts are you running RMS, or what amp is that you have?
Old Jan 19, 2009 | 02:20 PM
ohh well ok yea thats gotta go..lol...rms i think im running about...eh lets say at 2ohm its 500 and at 4ohm its 310...and thats only with one sub...its a mono block PROFILE California Amp 1000w
Old Jan 19, 2009 | 02:24 PM
t00fatt's Avatar
Then defiantly don't run that extra sub, give that L5 everything it wants. If you want a cheap improvement, build a sealed box for it, it will sound better.
Old Jan 19, 2009 | 02:25 PM
yea because ive been lookin for sealed boxes for it but well i have found none....
and what about the wire question? do you know which i should use??
Old Jan 19, 2009 | 02:29 PM
finch13's Avatar
ORIGINAL: AccordLXMaster
Because the best box is the one you build yourself.
