Central MT, WY, CO, ND, SD, NE, KS
legit search sites for specific accords
Old Jul 1, 2020 | 05:12 PM
lamarpismo's Avatar
Default shipo
verify for me pls..that part #10-4041 --is a typo correct number -10- 4014-- -
Old Jul 1, 2020 | 05:36 PM
shipo's Avatar
Old Jul 1, 2020 | 09:48 PM
lamarpismo's Avatar
thank you ..no problem ...just checking didnt want to get it wrong ..I only have the very slightest click in thirid and over the years have learned to favor and egg shell it so no problem..it has me trained...thanks for the info amoazon is packing mine as I type...
Old Jul 5, 2020 | 06:34 PM
lamarpismo's Avatar
Thank you for the information on the transmission fluid I'm just finishing up my two hundred thousand mile check up, early, 194,000 miles everything's done except antifreeze and transmission fluid and a fresh oil change--08 si orig owner
Wonder if I could bother you to take a guess at what it might be causing a flutter in the exhaust? standing behind my 08 Civic SI at idle there's a definite random without a pattern flutter--
that used to mean valve problems on Old Flathead Fords that's how old I am but I think maybe there are plates and brackets etc inside the exhaust system maybe in the converter etc that might be causing it? but I only think that? would you take a guess at what that might be? this car is very well maintained
I have Skype on my iPhone if you would if you require live listening and seeing it --we can do that- simply letting me know ahead of time to set it up not a big deal for me--
And thank you once again your transmission fluid is here no problem jeff bozo is on the ball...
Old Jul 8, 2020 | 09:02 PM
lamarpismo's Avatar
probably should not have asked you personally, should post in proper slot that way I will 35 different and incorrect answers ....but will wait a bit ..you may have time soon and thank you.
Old Jul 9, 2020 | 06:34 AM
shipo's Avatar
Quite honestly, diagnosing such issues over the internet is quite the challenge, if not virtually impossible. That plus I've never spent any significant time with an Si of any generation. Have you had the codes read to see if the engine is throwing any?
Old Jul 10, 2020 | 09:12 PM
  #17
lamarpismo's Avatar
No but it goes in next tue for the finishing up the 200000 mile maint. tranny fluid etc...runs great but will cover that then ..have already asked him and like most of these guys he takes a guess based on his experience in this case significant experience all he does is hondas he is the one that came up with loose **** in the exhaust and to start looking for another car --but just did the valves plugs runs great...I just know that flutter is not there on a new car of any kind. thank you
GRAY WHISKERS
Nov 2, 2008 02:41 PM
vintageant
Jul 26, 2008 02:27 PM
finch13
May 28, 2008 04:54 PM
wtony
May 24, 2008 07:47 PM
