Sticky center console
Old Jan 10, 2010 | 12:39 PM
Low Miles's Avatar
Default Sticky center console
Anybody else have this problem. The whole console is very sticky. This is my 2nd accord and the first had the same problem. It is the area by the cup holder to the compartment for storage. ANY CHEMICLES WE CAN USE TO SOLVE THIS PROBLEM.
Old Jan 11, 2010 | 10:35 AM
Only when my wife spills coffee or soda...
Wet cloth along with some cleaner like SimpleGreen diluted pretty watery. Then put some kinda plastic treatment stuff on it so it doesn't get too dried out.
Old Jan 12, 2010 | 06:42 AM
Low Miles's Avatar
It is not as simple as using a de-greaser. It is a defect in the center console.
Old Jan 12, 2010 | 10:12 AM
I don't get it. So the sticky stuff comes oozing out of the plastic itself? I guess I just never saw that.
Old Jan 14, 2010 | 12:46 PM
dfaulkner's Avatar
pics?
Old Jan 15, 2010 | 12:09 AM
keep_hope_alive's Avatar
i've disassembled my center console many times, it is never "sticky". i assume you're referring to the 2001 LX for sale? And your console looks like this:
the trim ring around the shifter pops off. is it associated with that trim ring?
Old Jan 15, 2010 | 07:36 AM
Low Miles's Avatar
I googled the problem and came across several other honda accord owners with a simular problem. The whole console from the pocket under the raido throuth the cup holder door has a very sticky feel. It might be a chemical used in the past that deteriated the plastic? The are is where the wood kit pictured above it located. I guess I can buy a wood kit like the picture above to overlay the problem area.
Old Jan 15, 2010 | 11:48 AM
i sanded the wood kit and painted the center console trim (it's silver now). that would be cheaper than buying a kit.
Old Feb 20, 2010 | 07:33 PM
DSeng13's Avatar
I painted mine also and it's not sticky at all. I never really noticed before when it was wood trim. Not around the whole thing anyway, but more on the edges of the whole center panel. It would seem greasy and every little piece of dust or little chipped things would stick in it and look ugly. What I did was remove the panel and clean around the edges with some kinda cleaner, lemon clean, orange clean or something and it went away for awhile. Not sure if it would have lasted though, as I said earlier I ended up painting it.
Old Feb 22, 2010 | 12:00 PM
Low Miles's Avatar
I figured it out. It is because of our climate. We are in South Florida and the heat is really bad. It must have caused the plastic to get sticky. The interior of the car can reach temps of over 130 degrees in the summer time.
