Things that have helped in exterior detailing
Old May 20, 2011 | 09:45 PM
frmrpriownr's Avatar
Default Things that have helped in exterior detailing
In the last year, I stepped the game up to using two large 5 gallon buckets for washing and I use grit gaurds in bottom of buckets. I bought a white genuine sheepskin mitt which is good for showing when it picks up dirt. That 2nd bucket is for rinsing that mitt often. when I start washing near the lower panels, I know the mitt will pick up more dirt and I can see it.
No sense in dipping it back into the soapy water, must rinse mitt first.
Drying is going better. sure, take nozzle off and sheet water off, use a bit of electric leaf blower around the mirros and such.
Big thing that has helped is to use a spray wax while drying the car. Weird things happen when just trying to completely dry a car - get streaks, maybe tiny water spots or it just doesn't dry completely.
No prob anymore - drying towel is for getting bulk of water off a section. Once that is done, I set towel down, pick up spray wax and microfiber cloth - spray some wax on car and wipe it down. If will overspray, i just spray onto cloth.
Best thing is when I'm done, the shine just pops big time. Plus, there's more wax onto the paint which helps.
Old May 26, 2011 | 07:37 PM
phatboyslim2012's Avatar
hey let me suggest that using laundry detergent greatly helps in geting a car clean, with road oils dirt and grime, less scratching, and shines much better than most auto cleaning detergent, id also suggest using a consentrate, as you will need less detergent. you will be surprised with the difference in effectivness
Old May 26, 2011 | 09:49 PM
keep_hope_alive's Avatar
thanks for the good information!
Old Jun 29, 2016 | 12:31 AM
Redaccrdo6's Avatar
If you really wanna get your car super spotless is using clay bar. Takes a bit extra work but man it looks awesome by the time your done.
Old Dec 7, 2016 | 10:40 PM
Accord_Drive_Time's Avatar
Just beware that it will also remove the wax protecting the car so be sure to wax it after.
hondamike887
Feb 7, 2011 02:20 PM
uraceulose
Nov 5, 2010 08:03 PM
Tarsis
Jun 13, 2006 10:27 PM
ozman05
May 23, 2006 01:28 AM
Jason@autogeek
May 11, 2005 02:24 PM
