wet paint help needed
Old Jun 5, 2007 | 12:23 PM
hawaiian5's Avatar
Default wet paint help needed
does wet paint actually protect like wax?. i bought some and used it, it works like a charm as far as making my accord really shinny. theres no doubt that it has a wet paint look to it. but it seems like it doesnt beed the water like a wax. when it rains around here, the water leaves behind little spots. it wipes off easy, and it aint hard water spots, just like little dull spots. like i said, they wipe away easy. WOULD I BE ABLE TO PUT A THIN LAYER OF WAX OVER WET PAINT AND STILL KEEP THE SHINE?. WOULD PUTTING A WAX OVER WET PAINT EFFECT IT IN ANY WAY?
Old Jun 5, 2007 | 05:41 PM
RTexasF's Avatar
Super Member
Default RE: wet paint help needed
First off it's a very good idea to apply/remove WPtwice. By doing so you assure complete coverage. WP has a sealant in it that does protect the paint. The fact that the water spots wipe off easily without leaving marks attest to that. Applying wax overitwon't harm anything and may enhance the shine and depth even more. I top it with Duragloss Aquawax (a sealant)or Optimum wax somethimes. Do NOT use a cleaner wax though or you're back at square one.
Here's WP with Aquawax atop it. It's on my gal's champagne colored Corolla. This combination makes it easy to get depth from light colors.
[IMG]local://upfiles/127/45817324F7554E1FB6E24BAFCC09B231.jpg[/IMG]
Old Jun 5, 2007 | 09:18 PM
hawaiian5's Avatar
ok, so if i put a coat of gold glass, it wont take away from the shine? i want the water to bead more, but i dont wanna loose that wet look. also, say i use a buffer, and buff my car with a rubbing compound. would u suggest just using wet paint over it?, or use something else along with wet paint?
Old Jun 6, 2007 | 07:13 AM
RTexasF's Avatar
Super Member
Assuming the paint needs it I would compound/polish then apply WP with the buffer(softfoam pad) until it almost disappears into the paint. Wipe it down and check the look. I've never used gold class so try it on a spot and see how it looks. If it improves theappearance then go for it. Wax only lasts 3-4 weeks so you will need to reapply fairly often.
If you don't have a soft finishing pad then apply by hand.
Mahalo
Old Jun 6, 2007 | 08:53 PM
hawaiian5's Avatar
ok thx. i have a buffer that uses terry cloths. is that ok?
Old Jun 7, 2007 | 07:02 AM
RTexasF's Avatar
Super Member
It will work for application or removal. Not enough power for compound or polishing though. Make it shine and let's see the pictures!
Old Jul 13, 2007 | 12:11 AM
SpanishN00b
i hate when that happens
RTexasF
Nov 6, 2015 12:05 PM
thunder_x
Apr 2, 2007 11:58 PM
fireballer44
Mar 9, 2007 10:41 PM
mrmookie123
Mar 9, 2007 05:06 PM
Trav20
Sep 19, 2006 08:31 PM
