DIY Answers. This section is for the staff of HAF to post detailed DIYs in response to the requests by the members.
Setting Base Idle speed
Old Nov 4, 2016 | 12:58 PM
Gerryz's Avatar
Thanks for the very comprehensive message. Will get right on it.
Old Jul 15, 2019 | 01:05 AM
Rachel Ann Cook's Avatar
Extremely helpful. Thank you all who posted here. This fixed so much.
Old Oct 3, 2019 | 08:30 PM
Alex 'Kimo' Hawk's Avatar
Default 99 Accord LX 2.3l setting idle base speed (from service guide)
Here's what the service manual says for 98-02
It's not the IACV but the Evap plug.. Aloha!
The EVAP Canister Purge Valve is mounted on the firewall, behind/below the intake manifold.
Last edited by JimBlake; Nov 7, 2019 at 11:00 AM. Reason: location of EVAP purge valve
Old Oct 8, 2019 | 08:36 AM
Thanks for posting that. My method has worked for my 1998, but I can't argue against the shop manual...
BTW, welcome to HAF.
Old Feb 10, 2020 | 08:01 AM
Default Aloha
Aloha.. Hi Everybody.. Sorry to correct You Jim, but the EVAP pirgr valve is not on the firewall, it's located towards the front of the vehicle, on the intake manifold.. gonna look for s pic in my hundreds I've taken. Haha I've done basically EVERYTHING to My engine by now. The latest is, code p0325, replaced wiring (full of oil, long story), and sensor. Asked a friend for a 27mm deep socket, he gave Me a 1 inch. Sensor got wedged, tried to wiggle socket off and BROKE THE THREADED PART IN MY ENGINE BLOCK. Nightmares getting it out. Drilled hollow and Still not coming out. Even My 'screw out' set didn't work.. I swear this car is haunted. lol But, it's running!
Aloha❤️🤙💪💪💪💪😊❤️
Nightmare!
Black plug is EVAP purge.. this pic is September last year. It looks like a whole new engine now! Aloha
Old Jul 22, 2021 | 02:11 PM
Joshua Antaya's Avatar
Default Inspection in 9 days... ugh
Going to try this today. New IACV, new coolant/air hoses/ tune-up, fuel injectors, gas tank, charcoal canister, TPS, MAP sensor, brake booster, radiator coolant (full flush Asian blue, have been running it for years, 0 air bubbles every time), new gas cap, easy flush to trans, etc. Randomly started this crazy idle had P0505 coded, cleared that up, cleared up the air/fuel ratio codes, lead to map sensor, 3rd one (4th for the car), no code for MAP yet, idle still going crazy 1200-2200. 98 DX Model ( pain in the butt, DX has a few varied parts from all the other 98-02 models). Even picked up the manual cheap this week finally. Will report here if this process doesn't clear the issue.
drickman9
Oct 8, 2021 01:49 AM
abross
Nov 4, 2009 08:33 AM
mstakern
May 26, 2009 08:59 PM
Brash
May 20, 2009 04:00 PM
Accord_Ras
Dec 10, 2007 07:19 AM
