Do-It-Yourself Section This section is for requests for DIY help, not for general technical advice.
1994-1997 accord turn signal modification!!!
Old Feb 19, 2012 | 02:48 PM
phatboyslim2012's Avatar
Default 1994-1997 accord turn signal modification!!!
hey, so i recently modded my turn assemblies in my accord.
here is a diy with finally pics.
whats needed:
94-97 accord CLEAR assemblies, can buy from amazon for $30
2 sets of cig lighter/ashtray lighting wiring. can buy from your local salvage yard.
2 amber led's 2 white led's #74
2 drill bits to match the bulb adapters
some silicone gasket sealer
so once you recieve all the stuff for install.
start by modifying the adapters, two of the adapters will have notches on them, cut them off without destroying the adapter.
next drill the correct size holes on each side of the assemblies, be very carefull not to destroy the assemblies themselves.
now cut the wires from the adapters but leave enough wire to install the assemblies correctly.
install the new bulbs into the assemblies.
when i installed the assemblies i used wire taps to add the outer leds to the parking lights, and i installed a switch for the inner bulbs.
if done correctly you should have an assembly as shown below.
Size:  75.8 KBName:  IMAG0020.jpg
Old May 29, 2012 | 12:42 AM
Cody_754's Avatar
Almost A Senior Member
Looks good! I was thinking of modifying my bumper lights but I'm too lazy I just might have to do this though. Was it much work?
Old May 29, 2012 | 09:17 PM
fredrock's Avatar
This looks great... What do they look like with the headlights on? But that light is super bright. Looks good.
Old Jul 4, 2012 | 07:56 PM
Default op re
hey sorry it took so long, ill take a nice pic with my headlights on soon, the white bulbs are 6000k led's. with 8000k hid headlights both match looks really good, very easy to do cost less than $10 for the led bulbs i bought off amazon
jctable
Nov 1, 2011 12:05 PM
nathan5603
Sep 14, 2010 08:35 PM
NGD9283
13
Jun 16, 2008 10:39 AM
sailaja_giri
May 24, 2008 05:17 AM
jjhu00
Feb 27, 2007 08:15 AM
