Do-It-Yourself Section This section is for requests for DIY help, not for general technical advice.
2003-2007 HVAC Blower Transistor Repair
Old Jul 15, 2018 | 12:22 PM
  #21
warforpeace's Avatar
Hopefully i can revive this thread and get some needed guidance.
My blower motor in my 2004 4 door ex Honda Accord stopped working so i did some googling and found the blower motor transistor was a common problem. I pulled it and found the thermal fuse was shot. I de-soldererd the board and installed a new fuse. When i plugged it back in the blower motor started working but it comes on right when you turn the car on and it only runs at high speed no matter what you do from ac control. It also wont shut off. I checked my relays and fuses but they look good. I am wondering if this is a sign that i messed up my soldering? or if there is something else i should look at?
Old Jul 15, 2018 | 01:08 PM
  #22
It appears the power transistor is shorted closed. See attachments.
File Type: pdf
Old Jul 16, 2018 | 08:13 AM
  #23
bent_rod's Avatar
Originally Posted by MegaBite
Been looking all over hell trying to find the right thermal fuse. The one I took from mine is 140C ; 2 Amp. All the places I check are not the same and rated for A/C not D/C and nothing at the 2 Amp range. Any help where to go an get one? Thanks
This is not a conventional fuse to protect for over current. It is made to protect against overheating not over current. Select a replacement thermal fuse with a rating close to the original 140C rating and at least 2A. It can be a higher current rating with no problems. Most thermal fuses are used in A/C operated heating equipment but will work for this application.
elgart
Apr 20, 2013 10:31 AM
elgart
Oct 9, 2012 03:42 AM
kevin1517
Sep 5, 2012 10:23 PM
brahmabull
Jul 25, 2012 12:49 PM
jtimc7
Sep 2, 2007 08:17 AM
