Do-It-Yourself Section This section is for requests for DIY help, not for general technical advice.
What are all the different "water-temperature sensors"?
Old Dec 31, 2011 | 05:46 PM
outlaw423's Avatar
GOOD WORK..
GREAT INFO tHANKS!!
Old Jan 5, 2012 | 02:23 PM
outlaw423's Avatar
So I have a problem....my 95 4 cyl accord when it gets hot both fans come on for like 7 secs then they turn off then 1 min later they come back on for another 7 secs.....then I turn off the car fan comes on ...and keeps running for a long time....?please help
Old Jan 10, 2020 | 10:29 PM
FiReKiTTeN's Avatar
Originally Posted by JimBlake
4th-gen and 5th-gen
1990 to 1997 USA
4-cylinder engine
Beginning in 1993 the Europe/UK Accord 4-door was a different car, built in Swindon UK. Not sure if these sensors & systems are the same.
There's 2 fan switches and 2 coolant-temperature sensors.
Fan switch A is located in the thermostat housing. It switches the fans (both) when the engine is running. Pretty sure that works when the key is turned ON but the engine doesn't actually need to be running.
Fan switch B is located in the nozzle for the upper radiator hose, near the head. This one has authority to switch one of the fans, after the engine has been turned off. There's a timer to prevent the fan from running forever even if the switch-B is stuck.
"ECT sensor" Engine-Coolant-Temperature sensor is located roughly below the distributor. It has a plug with 2 wires. This sensor provides a coolant-temperature measurement for the ECM.
Lastly, there's another temperature sender near the ECT sensor. This one has only one wire and it provides the signal for the dashboard temperature gauge.
I know this was posted almost 9 years ago, but so very informative. Thank you, thank you, thank you. This was the bit of info that i so needed to help me figure out my coolant fan dilemma. It was the missing info that I needed. You are awesome! Now I can finish fixing my mom's car and get her fans operational again.
Old Jan 11, 2020 | 10:09 AM
You're welcome, I'm glad it helped. If you have troubles during the job, go ahead & post questions in General Tech.
Old Feb 19, 2020 | 03:05 AM
MrTire Expert's Avatar
Thank you so much for sharing this şnfo. This is just definitely what I needed.
Mad Professor
May 21, 2020 06:06 PM
Rilex
Mar 4, 2013 10:37 AM
HondaAficionado
Nov 30, 2010 05:24 PM
kriegz99
Aug 11, 2007 08:41 AM
Karthigan
Nov 27, 2006 02:55 PM
