02 Accord 5 speed Should I change fluid? What kind?
Old Jul 15, 2013 | 08:37 AM
JOE.G's Avatar
Default 02 Accord 5 speed Should I change fluid? What kind?
I have a 02 Accord with over 100,000 Miles Should I change the Fluid in it?
If so what kind?
How Much?
Where is drain and fill Ports?
Any Tips?
Old Jul 15, 2013 | 08:48 AM
Are you talking about transmission fluid?
Old Jul 15, 2013 | 11:21 AM
IF you're talking about manual-transmission fluid...
Imagine the right-front wheel removed, and you're looking in along the axle.
Drain plug is at 6-oclock and it has a square hole just the right size for a 3/8-socket extension.
Fill plug is at 9-oclock and it's a normal hex bolt, but larger and "looks different" from all the other bolts that hold the transmission case together.
Honda MTF. A bit less than 3 quarts. People have used Pennzoil Synchromesh, or Redline something-or-other, but if the factory stuff has worked well so far, then stick with it.
If you remove the wheel to do this, then lower the jack enough so the car is level. Then pour fluid in through a funnel & hose, until it pours out through the fill hole. You want to go slowly to give it a chance to flow around everything & actually be full at that level.
I said lower the jack, but be careful about supporting the car. I use jack-stands before I reach in or under the car. Once I have everything ready, so I don't have to reach anywhere underneath, THEN I remove the stand & lower the jack to level the car. Don't get your arm crushed underneath...
Old Jul 15, 2013 | 01:48 PM
JOE.G's Avatar
Yeah 5 Speed car, I ordered 4 Quarts at $5.00 a quart from your honda parts. Figured I prob should change it.
93Accord2.2
Dec 17, 2021 09:59 AM
62maxx
Oct 18, 2015 08:20 AM
andrew404
May 1, 2010 10:15 AM
MisterBen
Mar 2, 2008 08:23 PM
dejavustuff
Jan 14, 2008 12:14 PM
