1987 Honda Accord LX cranks but won't start
Old Oct 26, 2014 | 05:08 PM
lovemyoldaccord's Avatar
Default 1987 Honda Accord LX cranks but won't start
It has been suggested that we need to replace the Crankshaft Position Sensor however, we are unable to find where it is located on my accord or even where to purchase one? All help is greatly appreciated!!!
Old Oct 26, 2014 | 06:42 PM
Before replacing any parts, you need to establish whether spark or fuel delivery is the problem. Suggest attempting to start w/ a 5-10 second shot of throttle body cleaner or starter fluid into the carb.
If it starts, fuel delivery is the likely problem; fuel relay, fuel filter, fuel pump.
If it doesn't start, ignition is likely problem; coil, ignitor, rotor, cap, or coil spark output wire. It could also be a faulty ignition switch not providing power to the ignition system.
Old Nov 1, 2014 | 09:42 PM
Replaced the ICM starts up like a champ now! Thank you for the info!
frankferry
Jun 8, 2012 10:23 PM
Spectre
Jan 17, 2010 06:08 PM
jjrho
May 4, 2008 10:22 PM
LiquidR1
Sep 2, 2007 09:26 PM
thomks
Aug 15, 2006 06:43 PM
