91 accord SE, cranks but won't start
Old May 3, 2008 | 07:01 PM
jjrho
Default 91 accord SE, cranks but won't start
hi, have a 91 accord SE 2.2L with 150K....still doing well but few days ago, stopped starting.... it cranks and when i hold the ignition on, it seems to continue to fire but as soon as i let the key go, it stops....
where should i start? fuel pump fuse? batt is good.....the car has no other major issues so far... haven't even changed the crank seal yet...
pls help,
jim R
so calif,
'91 accord SE 2.2L 150K miles
Old May 4, 2008 | 08:24 AM
Default RE: 91 accord SE, cranks but won't start
A good place to start is a "fuel or fire" check. Spray starter fluid or throttle body cleaner into the throttle body intake (remove intake duct) while cranking the engine. Does engine fire briefly? If yes, fuel delivery is the problem; fuel filter, fuel pump, main fuel relay. If no, spark is problem; coil, ignitor, rotor, cap, wires, plugs.
Note, you don't replace all these parts, but must perform further diagnostics, once the problem is parsed to either fuel or spark.
Old May 4, 2008 | 10:51 AM
deserthonda's Avatar
ORIGINAL: jjrho
are you saying that if you hold the key on, it fires ( starts, runs) but as you let the key go it dies ?? .. If so you got a bad electrical portion of the ignition switch
Old May 4, 2008 | 10:22 PM
ORIGINAL: deserthonda
... If so you got a bad electrical portion of the ignition switch
Yeah, that's my guess too. See if you can keep it running by releasing the key partway. Or wiggling the key around.
frankferry
Jun 8, 2012 10:23 PM
maddogtheman329
Mar 26, 2012 03:15 PM
Spectre
Jan 17, 2010 06:08 PM
LiquidR1
Sep 2, 2007 09:26 PM
thomks
Aug 15, 2006 06:43 PM
