1996 Accord, Idle fluctuating, high RPMs. Vacuum?, EGR?
Dear Experts,
I have a:
1996 Honda Accord EX
~ 279K miles
2.2 VTEC engine
5 speed manual transmission
In earlier years, when stopped, the idle would be about 700 RPM
But the past year or two, when stopped, the RPM of engine races.
From what I remember, the RPM bounced between 1000 and about 1750 RPM.
It was much worse in the winter. Always high.
This summer, it was calmer. But rarely went below 1000 RPM.
After a lot of research, recently I changed the:
Honda 16500-P0A-A01
Valve Assembly, Fast Idle (Af41D)
1994-2001 Honda
16500P0AA01
https://www.hondapartsnow.com/genuin...0-p0a-a01.html
(OEM part)
Idle Air Control Valve (slow)
Honda 36450-P0A-A01
Valve Assembly, Electronic Air Control
1994-1997 Honda Accord
36450P0AA01
This is now discontinued, so I bought an aftermarket part on Ebay.
Yes, I bled the cooling system of air bubbles.
And, an aftermarket PCV valve from Autozone.
https://www.autozone.com/emission-co...3dl/918540_0_0
But the idle is still races high.
Yesterday, the idle fluctuated between 1000 and 1750 RPM
I've seen it bounce up to 2000 RPM.
Additional info:
Previous years, there was the check engine light code:
P0401
Exhaust Gas Recirculation Insufficient Flow
The past two years, in the winter especially, I keep getting the check engine light code,
P1491
EGR valve lift insufficient detected
Sometimes, only a few dozen miles pass, before it presents itself again.
q1:
Has anyone had any experience fixing a fast idle?
If so, what were the solutions?
Now I'm thinking that there might be a vacuum leak.
I took a look, and did not see anything obvious, like
disconnected, or cracked hoses.
And, started looking at vacuum and emissions diagrams, schematics.
Complex.
q2:
Has anyone had any experience fixing vacuum leaks?
If so, what was the solution and/or
hose (or gasket, etc) that had failed?
Thanks a lot!
I have a:
~ 279K miles
2.2 VTEC engine
Honda 16500-P0A-A01
1994-2001 Honda
16500P0AA01
(OEM part)
Honda 36450-P0A-A01
36450P0AA01
Additional info:
P0401
P1491
q1:
Complex.
q2:
Thanks a lot!
Here is an update.
As I mentioned, the Idle Air Control Valve (slow), 36450-P0A-A01
was an aftermarket part on Ebay.
Pics here:
Aftermarket 36450-P0A-A01 from Ebay 1
Aftermarket 36450-P0A-A01 from Ebay 2
There was no logo on this part.
Pics here:
However, after a lot of searching, I got to RockAuto.
And found some parts there:
https://www.rockauto.com/?carcode=1167410&parttype=6072
For the EX model, there was one part from Standard Motor Products, $221.
And another from WVE, Wells Vehicle Electronics, $145.
https://www.rockauto.com/en/moreinfo...167410&pt=6072
I ordered the Wells product.
Turned out that it actually has the OEM logo (Denso) on the part
Nice!
See the images.
Wells Vehicle Products, Denso, 36450-P0A-A01
The part number at WVE is: 2H1125
Wells Vehicle Electronics, 2H1125, Box
Nice!
See the images.
Forgot to mention, before ordering the second part, I
took the car to a shop, to get checked for vacuum leaks.
They found none, but isolated the problem to the
Slow Idle Air Control Valve
Thus, my searching for another part.
After I installed this OEM part, the engine calmed down completely.
Between 730 and 875 RPM,
Yeah!
Lessons:
Always go OEM parts, when you can
Wells Vehicle Electronics makes/sells at least one great part!
So, before anyone asks, why didn't I just clean the valve; the car is 27 years old.
New parts please.
Yeah!
Lessons:
New parts please.
