2003 random misfire
Old Feb 6, 2013 | 09:38 PM
belprk1971's Avatar
Default 2003 random misfire
NEED HELP !!
Wife drove her 2003 honda accord v-6 to work everything was fine. Went to leave 8 hours later and check engine was on and car was running bad (missing ). Borrowed a code reader and it shows all cylinders are misfiring and random misfire.
Car has 140k and has been well maintained, timing belt and w/pn done at 110k. Plugs also done then.
Any ideas will help.
Old Feb 15, 2013 | 11:31 PM
go-part's Avatar
Former Sponsor
When was the last time the ignition coils were replaced?
It could also be the Crankshaft or Camshaft position sensor that has gone bad causing the car to misfire.
Old Feb 16, 2013 | 09:55 AM
What codes were presented? P030X?. Anything else?
A failure in COP would be noted by one cylinder missing. All or most COP failure would prevent starting. Random miss is usually something w/ fuel or air.
What plugs were installed? OEM or other?
Old May 8, 2013 | 01:34 AM
blackbirdruiz's Avatar
i had the same problem. tried replacing everything else: plugs, coils, injectors. nothing worked until i found out it was a couple valves not seating well. need to tear into the motor and get a valve job
Old Jun 26, 2013 | 10:10 PM
Dkinsman21's Avatar
I would double check the plugs. I had a problem on another car like that. Did a full tune up. At the time I did that used sea foam in the intake/oil/gas. Ran just fine for about a month then got so clogged up with deposits being removed that it would not run. Replaced plugs again and oil change and good to go.
linden
Aug 16, 2017 10:39 AM
gary85_
May 7, 2014 05:07 PM
Rocket Rod
Jun 12, 2013 10:10 AM
Hondahonda
Dec 31, 2012 09:22 PM
Texas Tech
Jul 18, 2011 12:32 PM
