is the 7.5 amp fuse the correct one to remove?
Old Apr 5, 2007 | 02:40 PM
thunder_x's Avatar
Default is the 7.5 amp fuse the correct one to remove?
because i looked at my fuse thing, and it says the 7.5 is the backup radio
but there is a separate one for the ECU
im trying to reset my ECU after the installation of my SRI
and after i remove the fuse, am i supposed to let the engine run for about 15 minutes ?
Old Apr 5, 2007 | 02:45 PM
poser_pilot6
Default RE: is the 7.5 amp fuse the correct one to remove?
The 7.5 amp backup fuse is for the ECU and the radio both (at least on a 94). Pull the fuse for about 15-20 seconds. When I reset mine after my SRI install, I let it run for like 5 minutes, and then I couldnt wait anymore so I went and drove it lol. It worked out well.
Old Apr 5, 2007 | 10:52 PM
thunder_x's Avatar
and i would know if i removed the correct fuse for the correct time because the engine would be all shaking and stuff
until the ecu relearns everything, right?
Old Apr 5, 2007 | 11:01 PM
19Accord97
If you cant find the ECU here is the alternative:
Disconnect battery neg. cable
Open dorrs for 10 min. to ensure power is removed
Reconnect cable to battery
Start car
Let Idle for 10 minutes (DO NOT touch the gas @ all during this period)
Drive like normally and it will relearn it
There wont be much shaking @ all. Let us know how it goes!
thomis
Sep 4, 2012 09:31 PM
alyssapie
Aug 13, 2012 10:58 PM
tvandentop
Sep 17, 2011 06:42 AM
Jeffrimerman
Oct 20, 2009 11:45 AM
justinit
Sep 24, 2009 04:56 PM
