86 lxi
Old Dec 21, 2007 | 08:56 AM
86hondalximonkey
Default 86 lxi
hello, i have a86 accord lxi 2.0l 5 speed. for some time now it has been "cutting out" when i drive it, at a slow speed in like 3 or 4th gear. but the other day it was jerking around and we where going about 55 to 60 mph. what can cause it to do this, i was told it was the dis. cap and rotor....
Now i can do anything to a chevy or ford, i have a v8 s10 and so on... this honda is new to me...
Old Dec 21, 2007 | 09:39 AM
falkore24's Avatar
Default RE: 86 lxi
check ignition timing, wires for arcing, plugs may be fouled ..... if you change the plugs, NO BOSCH!!!!! Use Denso or NGK only. Also, there could be a problem in the electrical portion of the ignition switch ... a fairly common Honda problem. Dizzy cap and rotor should be checked as well ...... keep us posted on your progress!!!
Old Dec 21, 2007 | 11:25 AM
deserthonda's Avatar
Default RE: 86 lxi
good advice Falkore...[sm=smiley20.gif]....sprk plugs NGK BPR5EY-11,,
daemonhat
Mar 26, 2006 09:58 AM
Rated///M
Feb 16, 2006 02:50 AM
Sellmanb
Dec 27, 2005 03:02 PM
86accordlxi
Nov 13, 2005 04:09 AM
89LXi
May 23, 2005 11:43 PM
