90ex questions
Old Mar 31, 2007 | 12:25 AM
playaman's Avatar
Default 90ex questions
how do i extend the life of my boot(5spd), and what rpms should I be shifting on for best acceleration, and should i put in synthetic oil?(220k k/m)
Thanks
Old Mar 31, 2007 | 04:23 AM
deserthonda's Avatar
Default RE: 90ex questions
ORIGINAL: playaman
Thanks
I would have to assume you mean cv ( axle ) boot ?? if so you might want to spray it periodically with some wd-40 or any othr oil base chemical to keep them moist and keep them from drying out and cracking and eventually ripping .
As for shifting i never look at rpm i shift by feel .. so cannot give you an answer on that one
If you have the money use syntetic oil ,, if not any major brands will do ...5w-20,, 10w-30 .. the key is to change oil AND filter every 3- 3,500 miles ..if you use syntetic change it every 5000 miles
Old Mar 31, 2007 | 07:56 AM
playaman's Avatar
Thanks,also i noticed a clicking noise from the engine, Could that possibly be the power steering pump? Its a high pitched kind of loud clicking noise, what could that be?
Old Apr 1, 2007 | 12:43 AM
Shadow1992's Avatar
When do you hear the clicking?
Old Apr 2, 2007 | 12:55 AM
playaman's Avatar
on engine idle, basically when the engine is runnin even on higher rpms.
klrspz
May 3, 2012 06:29 PM
maxst2
Mar 17, 2005 01:44 AM
poff1986
Dec 11, 2004 09:36 AM
sviana
Dec 7, 2004 03:09 PM
maxst2
Nov 23, 2004 12:02 AM
