93 Accord EX m/t
So I'm having a problem with my 93 accord EX. Not too long after I replaced my alternator & spark plugs/wires my car would turn off whenever I would come to a stop while driving. I'd press the clutch to shift down & it would turn off. The oil & battery icons light up. I'm not low on engine oil although I'm not sure if it's tranny fluid & the battery isn't old. Any recommendations or suggestions would be highly appreciated.
How does it idle when you're just sitting stopped?
Just for grins, try these 2 things.
- coasting approaching a stop, shift to neutral & immediately take your foot off the clutch pedal - does it still die?
- idle in neutral if it's stable - then just press down the clutch pedal without doing anything else
That's good - it rules out a bad thrust bearing which can allow the clutch to push the crankshaft over a bit.
Check this out...
https://www.hondaaccordforum.com/for...e-speed-38734/
Set the "base" idle like that, including all the stuff I mention for you to check out first.
Honda idle-control system doesn't really get along with ad-hoc adjustments for "personal preference".
Check this out...
