94 Accord no fuel cylinders 3 and 4
Hi,
I jus replaced the head gasket on my 94 accord, got it running but it is not getting any fuel to cylinders 3 and 4. Pull the plug wires from these cylinders and the car runs the same. Before the head gasket it ran on all four very well.
I have ensured spark on all 4 cylinders, and I have used a test light on cylinders 3 and 4 at the injector lead and recieve an orange pulsing light when the test leads are on the connector pins.(I get bright white from the injector positive lead and a ground)
I have tapped, removed and cleaned injectors from 3 and 4 to no avail.
Any suggestions before I spend the dough to service the failed injectors?
It seems strange they failed I suspect an ecu or electrical issue although I have double checked all my wiring and grounds.
Use a piece of scrap garden hose as a stethoscope to check whether injectors 3 & 4 are clicking.
Use your test light to compare the flashing among all 4 injector plugs. Are #1 & 2 brighter than #3 & 4? If they ARE the same, then I'd say you've narrowed it down to bad injectors.
JACQUESFAUST
Dec 10, 2012 06:29 PM
alfi
Jul 7, 2011 10:24 AM
gxl1927
Sep 12, 2009 09:46 AM
