94 accord's rumbling noise
when my car reached 50-60kph it starts to produce a rumbling noise.
driving at a stragiht path, the noise is consistent like you hearing a muscle car givin a large BRROOMM!!!! but lessens at 40kph and below. is this a normal thing for a '94 accord? pls help. tnx. [align=right]
[/align]
[/align]
can you reproduce the noise at idle , by just revving the engine ??
if so, i would look for exh leaks ,, loose exh shields
if noise is only there when car is moving i would chk the tires and the wheel bearings
Noises are hard to detect over the net , people describe them in all sort of different ways , so we need as much info from you as possible
i own a 94 accord to and it will rattle when my rpm goes from about 1750 to 2000. The reason is because i bought it from my uncle owho lived in tuscon arizona and the motor mounts are all dried up. it is a very consistent rattle almost everytime.
