Accord 2.0 2003 VTEC ex camshaft
Old Aug 19, 2015 | 11:11 AM
kwakers's Avatar
Default Accord 2.0 2003 VTEC ex camshaft
Hi all.
I just decided to carry out a service on my new 2003 accord tourer and also check valve clearances so I started doing the valves first while engine was cold I took the cam cover of and found one cam lobe has started breaking up, the hardened surface is peeling off
At the moment I am having a bit of a battle with the warranty company as to what they consider to be (worn out or breaking down) I am saying the cam is failing. Anyway if the worst comes to it I may have to carry out the work myself. So any info would be greatly appreciated. Has anybody come across this problem on Honda cams before?
Old Aug 19, 2015 | 03:23 PM
Spalling of the surface sure seems like it wouldn't be "wear". To me, "wear" would have to be more like a uniform polishing appearance.
Has the warranty company actually looked at the camshaft yet? Got a photo?
Old Aug 20, 2015 | 06:12 AM
kwakers's Avatar
Default Camshaft breaking peeling
Hi again
I will try and send a picture of the bad cam lobe I am not sure how to send a picture. As I can't retrieve a picture from my tablet. Do I have to take a picture and add it as an attachment.? Is there no way of just downloading it straight from my gallery?
Old Aug 20, 2015 | 10:51 AM
Click the button "Go Advanced".
There's a section with additional options.
Click "Manage Attachments".
That should open a popup window where you can browse to the photos & attach them.
(Not having a tablet, I don't know where you have to browse to find the gallery)
Old Aug 24, 2015 | 07:53 AM
kwakers's Avatar
I am going to attempt to show a PIC of my poor camshaft. Worn or what???
Attached Thumbnails Accord 2.0 2003 VTEC ex camshaft-img_20150819_095356.jpg   Accord 2.0 2003 VTEC ex camshaft-img_20150819_095339.jpg
Old Aug 24, 2015 | 09:00 AM
shipo's Avatar
Beyond worn; more like toast. Time for a new cam and cam followers.
Old Aug 24, 2015 | 11:21 AM
Lack of oil lube is most likely reason for wear. Suggest carefully checking that oil is being delivered through galleries to top of the cylinder head. You may need to start engine w/ valve cover removed.
bossie
Mar 29, 2021 11:17 PM
snoopy4369
Feb 27, 2015 07:30 PM
kris_loehr
Dec 19, 2008 07:20 PM
