bad valves k24 06 accord
Old Apr 25, 2015 | 11:45 AM
slackreracer's Avatar
Ok, I am really pissed right now. Installed the new head, aligned everything for top dead center on both cams and crank, put the chain on, and then everything else. Turned it over to test compression, I still have nothing. What the hell? Could I have missed something and messed up another set of valves? I did everything by the manual. Any help would be greatly appreciated.
Old Apr 25, 2015 | 12:08 PM
No compression on any cylinder? Any strong resistance (compression strokes) when turning over?
If yes, then suspect your compression gauge is either rigged wrong or defective.
If no resistance when turning over, something is wrong. Most likely the valves are not sealing.
Check camshaft/crankshaft alignment carefully before any further rotation.
Old Apr 25, 2015 | 12:56 PM
Valves are not sealing. Non of the intake valves, aggressive and non aggressive lobes. How can I makes them seal better? Thank you for all your help by the way, people like you are the reason forums are so great.
Old Apr 25, 2015 | 02:59 PM
How are you sure intake valves are not sealing? Are they not opening or stuck open? Bent? Were valve/rocker arm gaps adjusted? No compression on any cylinder?
What did engine alignment check show?
It sounds like you may have been sold a defective head.
If valves were never correctly seated they might leak but should develop some compression. If adjusted incorrectly, they might never close and no compression would result.
Old Apr 25, 2015 | 04:06 PM
Second head also has bent valves, just not as bent as the original. Fun times
Old Apr 26, 2015 | 05:33 AM
That sucks.....
giulio76
Dec 29, 2012 11:16 AM
miami honda
Jan 19, 2010 05:34 PM
oldpitpony
Jul 20, 2009 03:56 PM
weekendwrench
Dec 14, 2007 05:24 PM
blackex19
Jan 14, 2007 02:01 PM
