Trying to figure out the name of cable
Old Apr 24, 2015 | 01:04 AM
Sfc13's Avatar
Default Trying to figure out the name of cable
I have a 1994 honda accord. The gas pedal is very hard. I noticed the cable that is below the throttle cable may be the problem,but I'm trying to figure out the name of this cable it's connected to what looks like a large round vacuum pump of some sort. Can someone tell me what this is. It's a 4 cylinder. Thanks
Old Apr 24, 2015 | 01:56 AM
Sfc13's Avatar
Default It's the cruise control actuator
. It's called a cruise control actuator.
Old Apr 24, 2015 | 04:23 PM
Thanks for useing the forum..
Old Apr 27, 2015 | 12:23 PM
Which direction is that cable wrapped around? It should be the same as the throttle cable. When you press the accelerator pedal, you're relaxing the cruise-control cable, not stretching it.
There's another cable from the throttle body, going down to the transmission (if it's automatic). THAT one is wrapped the other way, so you are pulling on it when you press the accelerator pedal.
Are the cables mixed up?
pr1madona
Feb 23, 2014 11:26 AM
Da Flash
Apr 28, 2011 08:07 PM
Iceman Indy
Jun 7, 2010 02:04 PM
abhijitgp
Sep 10, 2006 12:04 AM
