Trying to disconnect the shifter cable at the transmission
Old Apr 28, 2011 | 11:08 AM
Da Flash's Avatar
Default Trying to disconnect the shifter cable at the transmission
I recently pick up a '88 Accord auto/carbed for a great price and I am trying to pull the engine/trans. I got the motor suspended in the air with only the shift cable holding it in. I've removed the plate that covers the cable as in goes into the trans but try as I may I can't figure out how to disconnect this DAMNED cable from the trans.........HELP!!!
Old Apr 28, 2011 | 02:20 PM
Da Flash's Avatar
I figured it out, I had to remove the lower flywheel/torque converter shield then I could remove that cotter pin and withdraw the cable. The Haynes didn't explain that too well!!!
Old Apr 28, 2011 | 08:07 PM
Dang, had the answer...but you figured it out. Yes I dont like that either.
Need any other help please let us know.....go a few examples in the driveway that I might be of some use.
Sfc13
Apr 27, 2015 12:23 PM
pr1madona
Feb 23, 2014 11:26 AM
squeek
Jul 9, 2008 05:12 PM
toddyfresh
Sep 15, 2007 10:10 AM
ArcticHonda
Jan 14, 2007 07:48 PM
