Shifter Cable??
Old Jan 11, 2007 | 06:48 PM
ArcticHonda's Avatar
Default Shifter Cable??
Is this cable (shifter cable?) supposed t go above the sway bar?...its attached with a zip-tie which seems kinda ghetto. This picture is from under the front bumper looking aft. The only reason I ask is because my swaybar is coming off next week for new bushings. Thanks.
[IMG]local://upfiles/6435/D5AD176E2E114F8F9BE10A2223002DE1.jpg[/IMG]
Old Jan 11, 2007 | 07:02 PM
sir_nasty's Avatar
Default RE: Shifter Cable??
Unless there is something I don't know about I've never seen one of those cables run underneath the sway bar, my guess would be that someone screwed up and just zip tied it, run it over the top and screw the zip tie
Old Jan 11, 2007 | 07:24 PM
hondadude's Avatar
You are missing the 'cable guide' that is supposed to support the cable. Maybe a salvage yard would have one. It attaches to the underside of the body behind the rear subframe, should be a place for a 10mm bolt to thread in.
Yes I'm fairly sure the cable goes under the swaybar. Never really took note of it before?
Iwouldn't think that the engineers would want the cable rubbing on the top of thesway bar.
I'll check my son's car this evening.
Edit: Dateline; Fayettenam Akysaws [insert ticker tape machine sound here] Just checked , and the cable runs UNDER the sway bar, supported by the Cable Guide.
Old Jan 14, 2007 | 07:48 PM
MALSR's Avatar
There's supposed to be a bracket but I don't know if you have to thread the cable through it before installing it or if you can just hang it on the bracket.
pr1madona
Feb 23, 2014 11:26 AM
Nester6662
Dec 11, 2012 08:58 PM
Da Flash
Apr 28, 2011 08:07 PM
squeek
Jul 9, 2008 05:12 PM
toddyfresh
Sep 15, 2007 10:10 AM
